August 11, 2006 at 10:12 am #95
KeymasterJon,
I saw your photo of your shop in the photo gallery. Are the benches you use in the picture for fabrication area or just sanding?
They look pretty cool with a lot of ajustment.
August 11, 2006 at 10:28 am #6524John Cristina
MemberJon,
you must get more photos of those tables as well as the possible drawings for them if we like them. Please attach a cut list or even a DXF with all the parts. Just kidding but more photos would be great. I am sure I am not the only still searching for a better solution in this area.
Thank You
August 11, 2006 at 10:52 am #6525KCWOOD
MemberFrom what I can see, the middle supports are adjustable by sliding. These look really cool and seem to be able to level easily. Yep, pictures sure would help!
August 11, 2006 at 11:51 am #6526Jon Olson
MemberHello Everyone.. I can post some pictures but not until the week of 8/28 leaving for vacation today. We wanted to make benches that require us not to have to level off the tops. We took two old sawhorses and use some unistrut to connect them. KC is correct the middle pieces slide to accommodate sinks. There used mainly in the sanding department but we are in the process of changing out the rest of the shop.
More later.
August 12, 2006 at 8:29 am #6532John Cristina
MemberWhat was that part about vacation, I dont understand. What is that?
August 12, 2006 at 9:28 am #6534Andy Graves
KeymasterJohn,
That is when you take time off of work. Usually you go to a nice place that you have never been. Or maybe it is the same place every year where the entire family gets together.
The reason I know, is cause I have a friend that works for the “city” and he gets them all the time.
August 12, 2006 at 9:59 am #6538KCWOOD
MemberWhat is unistrut and where do you get it? Never seen it before….
August 12, 2006 at 2:45 pm #6539Steve Lefebvre
MemberHome Desperate sells it, so do a lot of electrical supply places. You can build darn near anything out of it. Its like an erector set for big boys. The basic metal channel is 1 5/8 x 1 5/8.
September 7, 2006 at 9:28 am #7337Travis Harper
MemberMy floor in our shop is just a mess. We are constantly trying to level benches. I would really like to see some more pics. of those benches.
Travis
September 8, 2006 at 5:19 am #7358Jon Olson
MemberSorry travis. Hope to post some Pics today.
September 15, 2006 at 5:54 am #7648Jon Olson
MemberMore pics
September 15, 2006 at 5:56 am #7649Jon Olson
MemberSeptember 15, 2006 at 7:59 am #7650Travis Harper
Member??? That channel sure looks bigger than 1-5/8×1-5/8. It appears to be about 1-5/8×3-1/2 or so. Help me out on this. Thanks
September 15, 2006 at 11:52 am #7654Jon Olson
MemberHello Travis its 1 5/8 wide by 3 1/4 high. Its not Unistrut. Its electrical channel called Power-Strut.
September 15, 2006 at 11:53 am #7655Jon Olson
MemberP.S. good call ont he Specs. Not bad for a Bronco Fan
