Cut a Corian Solid Surface Double Cut Seam for a Perfect Fit
I’ll walk you through the steps to double cut a Corian solid surface seam to create the perfect joint, ready for adhesive.
The process takes a little bit of time to setup, but with a steady hand and a consistent cut, you can achieve invisible solid surface joints.
____________________________________________
If you would like to help bring new content to this channel, please click the affiliate links below because each time you make a purchase, I will receive a small commission. Thanks for your support.
π EXACT TOOLS NEEDED
Makita GA4542C SJSII High Power Angle Grinder, 4-1/2″ – https://amzn.to/37GYYUc
Makita Plunge Router 3-1/4″ HP – https://amzn.to/34tz2t13M Random Orbital Sander β https://amzn.to/35EYV8S
Bosch Jig Saw – https://amzn.to/37CYKNP
Jorgensen 3706-LD 6-Inch Light-Duty Steel Bar Clamp – https://amzn.to/2HHVYfC
Irwin Vice-Grip Original Locking Pliers with Swivel Pads, 11-Inch – https://amzn.to/3oBHD5a
1οΈβ£ POWER TOOLS
Router 3-ΒΌ HP – https://amzn.to/3rao3he
Betterly Cove Router – https://betterleytools.com/products/c…
Sawstop 10β Table Saw – https://amzn.to/3l6kaaB
Β½β Corded Drill – https://amzn.to/2N3ZBPA
β
β Corded Drill – https://amzn.to/3eqmTdV
4-Β½β Grinder – https://amzn.to/30K3PiR
1β Belt Sander – https://amzn.to/2OBwSCd
Makita Electric Polisher – https://amzn.to/2Hql3vz
Hot Melt Glue Gun – https://amzn.to/3vePvgc
Bosch Random Orbital Sander β https://amzn.to/30zuTkF
3M 6β Random Orbital Air Sander β https://amzn.to/3bwla4N
Makita Rotary Hammer – https://amzn.to/3t5wlaA
Metabo 5β VS Angle Grinder – https://amzn.to/2OKS7Bt
Makita 1-1/4HP Router – https://amzn.to/3lcqZI0
Makita Belt Sander – https://amzn.to/30xdZTS
2οΈβ£ FABRICATION TOOLS
Jorgensen 6-Inch Clamp – https://amzn.to/2HHVYfC
Spring Clamp 3β Opening – https://amzn.to/38uSxD2
Vise Grip Locking Pliers – https://amzn.to/3oBHD5a
250ml Adhesive Gun – https://amzn.to/2N4spaI
1 ΒΌβ Hole Saw – https://amzn.to/2OBxXKh
1 β
β Hole Saw – https://amzn.to/3cjDNZ0
Universal Dust Shroud 5β Grinder – https://amzn.to/30C1shK
3οΈβ£ CNC ROUTER TOOLS
CNC Router Bit (Onsrud) – https://amzn.to/3mJ5xKg
ER32 CNC Tool Holder – https://amzn.to/34OvtxC
ER32 Collet – https://amzn.to/34PbFKS
4οΈβ£ SANDING AND POLISHING SUPPLIES
3M Wool Polishing Pad – https://amzn.to/2J2VLnv
3M Wool Compounding Pad – https://amzn.to/2TmEkQK
3M Perfect-It II Foam Polishing Pad Glaze – 1 qt – https://amzn.to/2HCjj29
3M 05954 Super Duty Rubbing Compound, 1 qt – https://amzn.to/37DfHI1
80 Grit – 6β Hook and Loop – https://amzn.to/3byEtdD
150 Grit – 6β Hook and Loop – https://amzn.to/3cd1EcA
220 Grit – 6β Hook and Loop – https://amzn.to/3rHCGcc
400 Grit – 6β Hook and Loop – https://amzn.to/38tMuPk
600 Grit – 6β Hook and Loop – https://amzn.to/30yImsN
Scotch-Brite Maroon – https://amzn.to/3cnF3Kv
5οΈβ£ MISC
Oatey 38711 Foam Closet Flange Spacer – https://amzn.to/3nnx8kt
PROFLO 2″ Brass No-Caulk Shower Drain Body – https://amzn.to/3lpN7xT
Oatey 31177 Plumbers Putty, 9 oz – https://amzn.to/36sNgu5
Scotch 3M 355 Tape – https://amzn.to/3nUFyzW
6οΈβ£ COUNTERTOP CARE & CLEANING SUPPLIES
Glass Cleaner – https://amzn.to/3rF4o9a
Bar Keepers Friend – https://amzn.to/34qLYA0
ScotchBrite Pad – https://amzn.to/3dURONf
OxiClean – https://amzn.to/2HCtXWC
Magic Countertop – https://amzn.to/3jxbmrY
Microfiber Cleaning Cloth – https://amzn.to/34Dx7Ci
Website – www.OliveMill.com
Follow on Facebook – https://www.facebook.com/OliveMill/
Follow on Instagram – https://www.instagram.com/olivemill_c…
?Music by Dj Quads?
? @aka-dj-quads
? twitter.com/DjQuads
? www.youtube.com/channel/UCusFqutyfTWR…
? open.spotify.com/artist/2VZrdImbvB03VWApYtBRr3
? www.instagram.com/djquads
ββββββββββββββββββββββββββββββ
Far Away by Declan DP https://soundcloud.com/declandp
Licensing Agreement: http://www.declandp.info/music-licensing
Free Download / Stream: http://bit.ly/2NhWC1F
Music promoted by Audio Library https://youtu.be/iTSpmnHMVS4
QUESTION β Have a question about Countertops, Fabrication or Anything Else? Post in the comments section of this video!
#olivemill #coriancountertops #solidsurfacecountertops #staron #wilsonart #himacs #backstand #fabrication #livingstone #dupontcorian #diycountertop #splash #kitchencountertops #corianseam #invisibleseam
Disclaimer: Wear safety equipment at all times. At times we remove safety equipment for the sake of filming. These videos are for entertainment and as such any process you follow is done at your own risk.
