Corian Solid Surface Ramp Sink Fabrication with Slot Drain
Corian Solid Surface Countertop Ramp Sink video shows the complete fabrication process to build a Corian solid surface ramp sink. From the fabrication to the mounting and sanding followed by the drain assembly, you will be able to get a great idea of how to make your own ramp sink.
I use a CNC to cut the initial set of parts for the sink. After the parts are cut, they are sanded and prepared for assembly. Careful preparations are required to keep the adhesive off the finished parts.
After assembly, the slot drain is assembled and mechanically fastened to the underside of the ramp sink.
