Corian Solid Surface Countertop Repair – Expert Guide
Repairing a Corian solid surface countertop can save a project from the trash bin. This repair consisted of eighty holes drilled in the incorrect location. Plugs were cut on the CNC to perfectly fit the holes.
Matching adhesive is used to glue the plugs into the holes. They are then sanded down flat with the top of the material. Finally, the plugs are sanded and finished to match the surrounding material perfectly.
Corian Solid Surface is the ultimate material with endless possibilities.
