July 30, 2009 at 8:44 pm #3805Gene McDonaldMember
ahhh just a hint of ,,,gotta get some night time pictures…Kinda fun..
Ill post some better pics when I finish the rest of the kitchen
July 31, 2009 at 12:17 am #53394Andy GravesKeymasterI thought that was a piece of bamboo in the edge until I saw the last picture with the light on. Really pretty cool.
July 31, 2009 at 7:18 am #53398Gene McDonaldMemberThanx Andy, I was a little nervous about this one…but it worked out fine after the prototype process…I darnnear bit my fingernails awf worrying
July 31, 2009 at 7:43 am #53399Brian StoneMemberWhat’s under the cutting board? Does the sink have a drainboard or did you add in a different material under there?
July 31, 2009 at 8:54 am #53404Gene McDonaldMemberBrian, underneath is going to be a drop in tray type pan which catch all that gunk and water residue…I have two strips of white Solid Surface rails holding up the cutting board, but not full bottom…you can actually see into the cabinet…Its a plumber idea that hasnt been fitted yet.
I just thought it was so much work and worry to have that cutting board in the top next to the sink…I suggested the cutting board layed on top and can go in the cabinet when not in use…man wrong suggestion to a designer/buyer
I couldnt belive they wanted to remove that section of vetrazzoif it went wrong I was covered, by R&D/prototype agreement.
But in the end I now kinda like the inlay cutting board..it is a little bit higher than the top to keep from knife banging when choppping
Ill show some more pics when done and share my thought on what could have been done better in case someone else wants to try it
July 31, 2009 at 1:43 pm #53418Jon OlsonMemberGene you need to get on twitter and twit that job. Get moving you slaker!
July 31, 2009 at 1:46 pm #53419Gene McDonaldMemberJon, I feel like a twit i CANT FIGURE IT OUT YET
July 31, 2009 at 3:13 pm #53422Jon OlsonMemberI call you next week. I can help
July 31, 2009 at 3:50 pm #53423Steve MehanMemberI like the idea of the R&D agreement. Good move Gene.
What is the inlay material?July 31, 2009 at 4:03 pm #53424Gene McDonaldMemberSteve, Avonite Amber glass, the rest of the kitchen is gonna have that as a full backsplash with illumination as well..tricky stuff but fun to mess wit
Jon thanx..I am registered…but it says What are you doing?…can I submit pics…oooppps Im starting to derail my own tread
July 31, 2009 at 9:14 pm #53432Linda GravesMemberGene,
Great design as usual. Now where is the matching switch plate cover?
August 3, 2009 at 12:22 pm #53451Gene McDonaldMemberYes Linda,…Now that you noticed it i hafta make them one..all that money and they tro a white 39c light switch plate…Amber glass would be cool…thanx for the tip…
August 3, 2009 at 6:02 pm #53458Un-AuthorizedMemberGene:
Is the Avonite bonded to the estone as a full sandwich, or is the edge estone to estone with a dado for Avonite?
Looks great as usual,
August 3, 2009 at 6:30 pm #53461Norm WaltersMemberGene, it’s always a loaded question with Joe, be verwy, verwy careful with your answer.
August 4, 2009 at 8:05 pm #53489Mike GladstoneMemberVery cool design Gene! Really like the use of avonite, what did you use to glue it up with? Integra? Akemi? Liquid Lamination glue?
Joe, just a guess on my part, but if it lights all along the edge, I’m going to go with it’s sandwiched all the way through
