September 10, 2011 at 12:29 pm #5238Brady HudsonMember
When installing showers WITH seats….
Do you:
Install the seat, then run the walls down to the seat(and up from the bottom side).
OR
Install the walls, then butt the seat to the walls?
BradySeptember 10, 2011 at 5:58 pm #69398Andy GravesKeymasterInstalling seats is a recipe for disaster.
Saying that, we have done it in the past. We would typically install the walls and then the seat making to use a truck load of silicone to seal it.
I was always skeptical but we never said no because that is what the customer wanted. Now we tell them we will not install a seat along with the solid surface or stone walls.
September 10, 2011 at 6:47 pm #69400Norm WaltersMemberIt depends on what are using on the walls. There are also liquid waterproofing materials you can use as a backup.
September 11, 2011 at 5:00 pm #69405Un-AuthorizedMemberAndy:
What is the big deal with a seat? No one sits in them anyway; it’s a prop for female leg shaving.
I’ve put in several and never had a worry or callback.
September 12, 2011 at 8:08 am #69408Tom MMemberOn the are occasions where we install a seat, we use the triangle tile thingy and flip it over. Easy enough for the install and it has a minor bit of flex for expansion/contraction.
September 12, 2011 at 10:20 am #69411Gene McDonaldMemberyes…I havent even done many shower surrounds..but when i did..it was just a simple thing…and call them leg props…not seat like Joe said…the word seat mean sit down…I then get into funny descriptions as to there is not enough room for some to sit down…if ya wanna sit down ..buy a bathtub willya
September 12, 2011 at 10:25 am #69412Andy GravesKeymasterPosted By Tom M on 12 Sep 2011 08:08 AM
Tom, what are these triangle tile thingies which you are referring.
Sounds fair enough Joe. The question now is, “how do you install them.”
September 12, 2011 at 10:11 pm #69424Un-AuthorizedMemberPosted By Andy Graves on 12 Sep 2011 10:25 AM
Andy:
Mark lines to indicate proper pitch and level of triangle. Liberally apply silicone to solid surface cleats that are held to the lines with hot melt until the silicone sets up. Silicone the triangle/seat on top of the pitched blocking. Forget about it.
September 13, 2011 at 7:13 am #69429Tom MMemberAndy,
These are the seat supports I am talking about. Strong as heck and costing a lot less than what I would have to charge.The idea with tiling would be to fill the pan with mortar and tile over, but with solid surface we just flip it and add the deck and fascia as necessary.
BY the way, is the interface for text management different now? I don’t get a font color and the URL insert doohickey looks different?
September 13, 2011 at 2:59 pm #69437Andy GravesKeymasterI deleted font color but the link thingy should be the same and work well. Does it not work properly? Do you need to color selector?
September 14, 2011 at 6:12 am #69446Norm WaltersMemberPosted By Tom M on 13 Sep 2011 07:13 AM
Andy,
I have used the Better Bench quite a few times, you still need to waterproof it with a liquid waterproofing membrane, not only to prevent leakage, but to prevent mold growth.
September 14, 2011 at 7:39 am #69447Tom MMemberNorm comes through with the pic!
Andy, I used to use the font color thingy because Firefox didn’t always auto color the link. I just manually blued and underlined it.
September 14, 2011 at 11:24 am #69451Andy GravesKeymasterGotcha on the color thingy. I will try to put it back, but need to find the code for color insert.
Do you just silicone the metal seat bracket to the shower walls and then put the top on or do you use brass inserts along with the silicone?
September 14, 2011 at 4:25 pm #69456Norm WaltersMemberAndy, that seat need to be screwed into wood framing, or into masonry with tapcons. It comes with screws and achors that expand behind the wall material, but I would never trust them.
Even though they are meant for shaving legs one at a time something much more devious may occur there.
September 14, 2011 at 8:08 pm #69458Un-AuthorizedMemberPosted By Norm Walters on 14 Sep 2011 04:25 PM
Norm:
Why would a shower attract any more devious behavior than a kitchen countertop, and we use silicone for those?
