October 7, 2006 at 6:29 am #267
Reuben Hoff III
MemberHello everyone looking for some help here. I am currently evaluating the tools that we use and seeing what we can afford to update to or not. I notice alot of guys using air tools and was wondering if this was more cost effective than running the electric? Also was wondering in the air tools if those sanders can be hooked up to vac systems and then what is the best size compressor and tank storage to use. I am currently a 2 man shop , but trying to get expanded in the next year or two to handle one or two more employees if that helps with size of things.
Thanks in advance.
October 7, 2006 at 11:58 am #8433Dani Homrich
MemberReuben,
Air sanders do come with Central Vacuum System. As for compressor size you need 18 CFM per sander used on a continuous basis. A good 5 hp will run 1 sander, to run 3 sanders you will need a 15 hp rated at 50 CFM. I have a Quincy low rpm that has been running for 35 years with only 1 repair, and that was a broken valve spring.
Dani
October 8, 2006 at 10:38 am #8445Shane Barker
MemberWe have a Kaeser screw compressor, 10hp with 42 cfm @ 110 psi, this unit is awesome, we also have a refrigerated air dryer on it. Clean dry air. We never have more than two air sanders going at a time along with the CNC and other miscellaneous items and we have air to spare.
October 8, 2006 at 10:38 am #8446Andy Graves
KeymasterAir sanders are excellent for sanding edges, coves and sinks. On seams, use the Festool RO 150 and on decks use the GEM. This will speed up the process.
Air is less cost effective in terms of power consumption, but it saves strain on the body and hands to use air sanders. You don’t have to hold the motor, all the power supply is at the compressor.
For now I say skip the huge air compressor because you can do the entire counter without it and it will only take you a bit more time.
October 8, 2006 at 10:40 am #8447Shane Barker
MemberI agree with Andy
October 8, 2006 at 3:37 pm #8456Reuben Hoff III
MemberThanks for the info. that was one of my other considerations was a gem sander, but I still struggle with using it in the feild or do you guys just take the Festool sander on the job site. I also would like to know what company supplies you with micron paper in the festool hole pattern or can you match up and blend in stard grit finish for feild sems with the micron sand from the shop? Just trying to find the best equipement to improve upon what I already do.
October 9, 2006 at 7:06 am #8466John Cristina
MemberReuben,
They make a shroud for the Gem Sander for dust collection at the job site, but the Festool is the best out in the field. If you sand with Micron in the shop then you must use the same (micron) in the field, even though there are equivalents in grits, they really are not. I would say contact FEDSAWDAVE for festool pattern micron but he is allergic to festool.
From your original question, Andy is right, the air tools are going to be more of an investment due to the compressor. If you plan on really getting larger then consider it. The Kaeser is the best and the price shows it.
October 9, 2006 at 8:03 am #8470Steve Crowhurst
MemberAhhh John, not allergic to Festool…AChooo… I would surely take the Festool out in the field before a GEM for the simple fact of bulkiness.I’d rather have the GEM in the shop because it is quicker. I let Reuben know that although we have mega amounts of Micron in stock…5″,6″,8″, 11 1/4″ in Hookit, Hookit II & PSA in 5 Hole, 6 Hole, 8 Hole, 16 Hole & No Hole…we have never sold Micron with the Festool pattern. We sell a bunch of RHYNO abrasive with the Festool pattern but the majority of it goes to woodworkers. With 3M, it’s a minimum order of 500 pieces per grit so if a customer only need a couple 50ct bags, we’re stuck with the rest. If it moves it’s here. If it does’nt, it’s not.
October 9, 2006 at 1:49 pm #8478Dani Homrich
MemberReuben,
If you need micron in Festool hole pattern I stock the 268L in 80µ, 60µ, 30µ, & 15µ, and if you need 100µ I will get it.
Dani
October 9, 2006 at 3:40 pm #8480Reuben Hoff III
MemberDani,
I am deffinitley interested could you email your prices etc at hoffstops@cozadtel.net.
I’ve been reading up on past post and I can see micron seems to be the only way to step up the finishing game. What is your thought on the Gem sanders for a small shop.
October 9, 2006 at 3:42 pm #8481william w
MemberGood grief! I had no idea that festool used a different pattern holes on the sandpaper. Our first festool is being shipped and here we are without sandpaper that will fit it. I gotta find your catalog, Dani, or your website.
October 9, 2006 at 3:42 pm #8482Sheldon Slate Products
October 10, 2006 at 8:00 pm #8535Norm Walters
MemberMy favorite tool is the Beaver Seam Leveler, just makes life easier. All you need is a pancake compressor for it.
October 10, 2006 at 8:45 pm #8536Shane Barker
MemberNorm,
My installers say they prefer the festool on grind mode over the seam levelers. Fast, easy and less mess.
October 11, 2006 at 11:11 am #8540B Dillon
MemberAl, put an envelope in the mail to you today containing RHYNO abrasive samples in the Festool pattern along with a RHYNO catalog.
Dave
