January 29, 2007 at 2:20 pm #723
MemberWe are attempting to make our first inlay. I do not have a CNC although I have access to a thermwood at a local cabinet shop. There experience is limited to processing panels. The first inlay is pretty simple, no overlapping lines, no joined images.
I have converted the bitmap file to a .dxf and .dwg file using coreldraw. I have two questions.
1) Is it reasonable to think that someone operating/programming a CNC in a cab shop can use these files to cut an inlay?
The first question from the cab shop is going to be about tooling. 2) Is there a standard enough response to that question to give us a starting point from which to work? ( ie.. will I be able say use an XYZ bit to trace the outline and then remove the inside material with an ABC bit),?
Or, have I grossly oversimplified the entire process?
OK, sorry, that was 3 questions.
chris
January 29, 2007 at 2:49 pm #13979Tom M
MemberChris,
First, check the .dxf file (or whichever the CNC programmer wants to use) in a CAD program. The sizing is probably fine, but Corel and Adobe can do wierd things with .dxf exports.
You will at least want to route the outside edge with a V shaped bit. I would think a 60 degreee will give you better sharp corners. A good Island fill process will lift the bit as it gets to the sharp points, letting the bevel keep a sharper effect from the route.
The rest of the island fill, in this case, should still use the V bit I would say. It is small enough where the time won’t kill you.
I hope this was clear enough.
January 29, 2007 at 7:09 pm #13987Chris Yaughn
MemberI forgot to mention that this is the same inlay that Mory very graciously offered to help me out on. If we can’t figure this out, he is going to be my safety net.
I spoke with the Avonite Rep today regarding resins. He said, and I gather from reading other posts here, that I can dye them to my liking with regular powdered dyes from an art supply store. Any hazards to watch out for when doing this?
Of course I’ll make and use the entire batch of each color at one time. (to avoid having to exactly match a previously mixed color)
Tom,
Thanks, that will give me a starting point for our first attempt.
January 29, 2007 at 7:17 pm #13988John Cristina
MemberChris,
I dont know what kind of art store you go to but not any pigment is good for any resin, you have to make sure you get the right pigment for the right resin, they are not all compatable. Whomever you buy the resin from should also be able to supply you with a kit. Certain pigments interfere with the catalyst or dont bond well in the resin.
January 29, 2007 at 10:34 pm #14008Tom M
MemberI have to say I have always had good luck with Align-Rite. Grab a laminate chip, if you have one that matches. If not, for an extra fee they will match Pantone.
January 30, 2007 at 9:16 am #14023John Cristina
MemberChris,
Align-rite is good stuff to do inlays with. Easy to work with, sandable fairly quick and good color matching. Sometimes I use an epoxy but that is a little messier to deal with plus you have wait usually til the next day to finish it.
January 30, 2007 at 9:31 am #14025Tom M
MemberOver on one of the “Insert Image” threads (1/29, about 2:00), I show some different color inlays. The most complicated one has to go in five times for the right route and fill in the right sequence. The easiest is one trip, even with two colors. We separate them with either hot melt or silicone dams.
The problem comes when you don’t get all the dam(!) material off and it gets gunked into the sandpaper. You can really chew into the fill that way, and it just plain sucks.
All these fills were from Align–Rite.
January 30, 2007 at 11:11 am #14034Chris Yaughn
MemberTom,
Thanks for the info, I saw the pics. I will give align-rite a try. I would prefer to get everthing from one source.
February 15, 2007 at 9:05 pm #15134Chris Yaughn
MemberWaiting for the resin to dry now, looking forward to finishing this sample.
February 15, 2007 at 9:10 pm #15135Chris Yaughn
Membersorry about that, I’ll shrink it next time.
February 16, 2007 at 1:05 pm #15164Jon Olson
MemberFebruary 16, 2007 at 1:05 pm #15165Jon Olson
MemberWe like to mirror cut inlays. Not a big fan of resin inlays
February 16, 2007 at 1:07 pm #15168Jon Olson
MemberFebruary 16, 2007 at 1:09 pm #15169Tom M
MemberJon,
I truly hope that would be for the new stocking warehouse, but I shan’t be surprised if not.
February 17, 2007 at 6:54 am #15201Jon Olson
MemberHello Tom. It’s for there building over in Hopkinton MA. Not sure what type of building. I’ am just the janitor here.
