June 2, 2009 at 5:46 pm #3683Norm WaltersMember
Has anyone ever seen anything like this? It’s not a stain, it’s the actual pigment in the material that has crytalized. I have been dealing with a warranty claim on this for three months now, if it isn’t taken care of this week I’ll let you all know what brand it is. I’m pissed, I talked the customer into putting the same product in three bathrooms and a kitchen.
June 2, 2009 at 7:46 pm #52346Un-AuthorizedMemberNorm:
Assuming the top was not installed in this condition, what does the customer say happened? Is this supposed to have just appeared one day?
It looks like heat damage to me. It also looks like Cambria, they’ve got the large particulates like that.
On second look, I take back the heat damage. Possibly someone cleaned the deck with a nasty cleaner, then laid a rubber drain mat on top of it while it was still wet, preventing evaporation and enhancing a chemical burn. That would fit the damage pattern nicely.
Norm, people try to falsely calim warranty coverage. I just did an inspection for a major solid surface manufacturer that had all the classic heat crack symptoms, yet the guy insisted that it just cracked on its own. Frame it like this to the customers: “Is is possible that someone (son or daughter) set something excessively hot here and aren’t saying? Not that they did, but is it possible?” If it wasn’t installed like that, someone’s lying or being lied to.
June 2, 2009 at 7:51 pm #52349Dani HomrichMemberNorm,
It doesn’t look like a defect to me, more like HEAT damage. The Quartz crystals look clear and that is an indicator that something very hot was placed in that area. I have done several repairs where the customer said the material was defective with the same type of damage and all were from heat damage. If the Quartz crystals are clear they have received too much heat causing them to separate from the polyester binder. When the crystals get to much heat the polyester shrinks causing the crystal to turn clear, because the color in the resin is no longer touching the crystal you only see the light reflecting off the sides of the crystal not the color of the resin. As for a warranty claim there is none for heat. A good closeup photo would help.
June 2, 2009 at 9:53 pm #52356Chris YaughnMemberLook in the cabinet under the sink and see if they have a “George Foreman” grill.
June 3, 2009 at 12:15 am #52357Karl CrooksMemberYes we have seen that type of damage, it is heat or chemical damage, and does not look to be a warranty issue sorry.
June 3, 2009 at 6:05 am #52358Norm WaltersMemberIt was already inspected by a manu rep, it is a warranty issue. The problem is the amount of time it is taking to resolve it. The first pic is a bathroom vanity top.
June 3, 2009 at 7:39 am #52360Brian StoneMemberMy first thought when I hear the description you gave is heat. Since the second one is right next to the sink like that it makes me think that they used a chemical that they shouldn’t have and put their dish drainer over the top of it.
June 3, 2009 at 8:40 am #52361WayneMemberSunlight somehow?
UV rays turn ES white.June 3, 2009 at 9:13 am #52362Karl CrooksMemberPosted By Norm Walters on 03 Jun 2009 06:05 AM
Norm if the manu rep already called these warranty issues and that was told to the customer then that’s the path they want to go down. Will they try and repair them or replace these tops?
Its to bad when the warranty process gets delayed, this just cost everyone more time and money, its very upsetting to the customer and they always seem to find more things they dont like about the product or the job.
June 3, 2009 at 10:51 am #52365Brian StoneMemberIf it’s the same damage on both tops them I would tend to think that it’s damage from an improper cleaner. If they want to cover it under warranty then it’s good for the homeowner. I’m surprised it’s taking so long to process. Like Karl said, the longer they take, the more the homeowner will find wrong with something else or even the new tops.
Joe – the more I look at the picture of the kitchen top, the more I think that it’s HanStone.
June 3, 2009 at 6:33 pm #52382Andy GravesKeymasterThe only thing that leads me to believe it is the material is the fact that it is in two completely different areas. One is the kitchen and the other is the bathroom.
If it was a cleaner, why wouldn’t it effect the entire piece of material and not be isolated to one spot.
If the damage gets worse over time it may be the material.
June 3, 2009 at 7:22 pm #52385Norm WaltersMemberHere is the reason why I know it isn’t heat damage. Shortly after the tops were installed the customer told me they damaged the countertop next to the range with a hot pot. It was at that point that they read the care and cleaning instructions and realized that the heat damage was on them. We replaced that section of the top for $600. I am fairly confident that they didn’t do it again, and that they read the care and cleaning instructions verbatim after that.
They realized the replacement was on them that time and graciously paid for it. Now it is on the manufacturer, and three months is ridiculous. This was a large remodel for me, in a densely populated area of upper middle class homes, a huge resource for referrals. How much is this delay costing me, I am the person that sold this to them. Do you think I will be selling any more of this product??
June 3, 2009 at 7:47 pm #52388WagsMemberDo you remember a few years ago, on a stone forum, that a class action suite was being discussed against a major quartz mfg, for exactly this reason. Their failure to honor warranty issues. Not sure what happened to the suite but they are well known for saying if we shipped it, it was good so its not a warranty issue.
Good Luck !
June 3, 2009 at 8:23 pm #52391Steve MehanMemberNorm,
Many have posted it being either heat or chemical damage. If the manufacture rules it that way also and determines it not a warranty issue, and can prove it by possably recreating the damage on another piece of material. Have you thought how you will then handle this? Also have you used this product many times in tha past?
June 3, 2009 at 8:26 pm #52392Norm WaltersMemberTom, as a manufacturer you can spend all the millions you want on marketing, but if you don’t take care of blatant warranty issues in a timely manner your fabricator will stop selling your product. You know as well as I that you can switch a customer from one material to another because they rely on your expertise to steer them in the right direction, it just not good business sense to expedite warranty issues.
