August 15, 2009 at 8:47 am #3841Max IsleyMember
I have been under the impression that at least some digital templating systems produce digital files that are truly CAM ready and do NOT require CAD work prior to sending the files to the shop floor (This means either importing to 3rd party software prior to sending the complete file or sending to the production office to do so there). I am now getting some conflicting information on this subject and would like to hear from someone who actually knows the facts.
August 15, 2009 at 3:05 pm #53659Paul BinghamMemberHi Max,
We use digital templating, an LT55, the PDA version. We bring our files back to the office and work them in Autocad to produce a file that can be sent to the appropriate software for the CNC where we assign tools and cut speeds, etc.
If we used the newest versions with the full computer, it would be possible to do the job on site before returning to the office, but I don’t see any advantage to doing this.
If you want to optimize for material use, you have to do some CAD work, whether it’s SS or stone you are cutting.
The procedure usually takes about a half hour to 45 minutes from template file to ready to cut file.
We have some very expensive software that optimizes part layout, but I can do a better job manually for cutting SS than the software does. It’s faster, but I’m better at saving material. Ultimately the saved material is worth more than my saved time.
Paul
August 15, 2009 at 3:19 pm #53660Max IsleyMemberThanks for the response Paul. Do I understand correctly that one must CAD the field data with a third party software, no matter if it is in the field or in the office?
August 15, 2009 at 3:30 pm #53661Andy GravesKeymasterI know there are programs out there that will do what you are asking for the cabinet industry but haven’t seen one for countertops. Because countertops are typically bigger than the material, it is really important for seam placement to manually nest the parts.
What specifically have you heard and from what company?
August 16, 2009 at 9:35 am #53669Max IsleyMemberHi Andy. I hope all is well with you.
I ask because I am trying to educate myself about the facts within the industry instead of believing the hype or assumptions I might make from available info. I have been led to believe that the industry standard is that the dxf files that are produced from most templating systems are not CAM ready, but still must be manipulated to get details input in order to then import to CAM software (I am told AlphaCAM is the most common). I also understand some to claim that this CAD step can be avoided but I get conflicting feedback of the reality of this claim. I do not want to make any incorrect assumptions or conclusions until I know the facts and I am having difficulty getting them. I wish those who make comments about anything in anyforum or out in the market would do the same before making claims without the facts. If we are all more knowledgeable about the facts, we can make better decisions.
August 16, 2009 at 2:42 pm #53671Paul BinghamMemberI can’t imagine that any of the software with digital templaters can do what I want done at this point in time. As Andy mentioned placement of seams and the way we cut seams is not likely to be accomplished well with any automated software. We have software that can take a cabinet design file and with four mouse clicks generate a series of cut files for melamine sheets, but it won’t work well for cutting a SS top for a number of reasons.
We often cut tops with a cove backsplash and a scribe strip and a 1 1/2 ” stacked edge. This requires making decisions on where to make the 1/8″ recess at the back of the top and where to slice of the scribe strip from the digital file. The software can’t do this effectively. We need to make quite a bit of 7/8″ strips for the cove piece and the actual backsplash as well. If we cut this it’s true length from the sheets it would make for considerable waste. We use smaller unused areas of the sheets and many times we have less than 2 or 3 % waste in three sheets. No software that I’m aware of can do this properly.
The template software puts out a DXF file, but I’m not aware of any CNC machine that can use that file directly without it being converted to the appropriate code for that machine. That’s what the CAM software does.
Paul
August 16, 2009 at 5:11 pm #53672Max IsleyMemberThanks for the in depth comments Paul.
My question does not involve the CAM step. I seem to have a clear understanding about that and I understand the need for it from what you and others have told me. What I am trying to clarify is if any system avoids the need for 3rd party software in the “field to CAD” step (prior to importing it to CAM). It has to do with if it is possible to eliminate this bog in production. I apologize for my confusing things by not being clear.
August 16, 2009 at 7:07 pm #53673Paul BinghamMemberNo matter what digital template system you use, it will only provide you with an outline of the top to be cut. The new LT55 will give you a large screen and CAD capability in the field, but you will still have to break the top into pieces that fit the sheets and generate the pieces for edge buildup and backsplashes, etc. and place them appropriately to be cut efficiently. I don’t think any system is capable of going from templater to CNC. Some CAM packages allow you to do the manipulation in the CAM package without using something like Autocad.
Paul
August 17, 2009 at 8:07 am #53683Brian StoneMemberAt this point you are going to want to use some kind of CAD software between the template and CAM step.
We have an LT-55 with the tablet. With some work in the field you could have a file for a stone top that could go straight to the router. I think it could be done a lot faster on a computer with some type of CAD program though.
I wouldn’t even think about doing a SS job on the tablet with all of the extra buildup pieces that you need. It would take forever.
August 18, 2009 at 6:52 pm #53730Andy GravesKeymasterI think you will find using a CAD program will be much faster than trying to perform that operation in the field. That said, I think you can do it with the LT55 tablet and the Proliner.
August 24, 2009 at 3:29 pm #53836Gordon ShellMemberIf you use all the features in the LT-55 software you will be able to process both SS and stone tops from it. to accomodate for the build-up in ss you just use the add backsplash feature and enter the width of your build up, touch the edge that needed build up added and it will add that strip to your drawing, tap it again and it gives you your second piece of build up. while you are drawing your tops it is also calculating your square footage of material.
Laser products has done a good job of making the LT-55 a complete system, if you see somthing that it is missing you just let us know and we will work on adding it to the software.
There is a seam placement option in the software that allows you to place the seam, break apart the tops at the seam and lay them out on your slabs.
I will try to put together a couple of screen shots of the above features.
I am a distributor of the LT-55XL and a former employee of laser products, feel free to contact me direct with any questions you may have.
gordon 616-293-6170
August 25, 2009 at 8:51 am #53848Gordon ShellMemberKind of blurry but this drawing shows edge build-up strips and seam placement.
August 25, 2009 at 1:42 pm #53849Andy GravesKeymasterGordon,
If you add an inside and outside radius to the countertop, can you still do the offset for the buildup? I would like the buildup to be one continuous piece if possible.
August 26, 2009 at 9:32 am #53856Gordon ShellMemberAndy,
Yes you can do what you described, we have an option called offset scribe line, it will capture all of the radii and offset them with the stright edges, you just offset them again the width of your strip (example 1″) and close the ends, you will end up with a 1″ strip that will fit exactly under the front edge.
I will try to do a demo screen shot for you soon.
August 26, 2009 at 6:44 pm #53864Andy GravesKeymasterThat would be interesting to see the process. Thanks Gordon
