August 22, 2006 at 8:57 am #121
KeymasterHelp me out here. What is your:
- IPM (inches per minute)
- RPM
- Router Bit diameter
- Number of flutes
- Upcut, downcut or straight
August 22, 2006 at 9:31 am #6797John Cristina
For 1/2 material we use:
420 IPM for the 1st pass 450 to remove last .04
18000 RPM
1/4″ bit
Single flute
Upcut the down cut bit was forcing the shavings between the material and the spoil board.
August 22, 2006 at 1:00 pm #6806Rich Day
MemberOK guys I am getting confused. What was the question? Are you saying that you do most all of your cutting with a 1/4″ bit?
August 22, 2006 at 3:33 pm #6809Seth Emery
For cutting 1/2″ solid surface we use:
250 IPM (one pass)
18000 RPM
1/4″ Dia.
Upcut “O” flute
John,
Wow – 420 IPM is cruising. I imagine you are taking two passes to keep parts from moving. Does the operator still have to stop the machine to remove build-ups before routing the other parts? Do you still take two passes on large parts? On the second pass, are you taking any material off of the perimeter of the part or just dropping down .040″?
Rich,
Yeah, 1/4″ dia. tool does the trick. A 1/2″ dia. tool is overkill and will cause more pressure that will cause small parts to move easier. We use a 1/2″ dia. tool mostly for plowing and for cutting faucet holes so the slug left from the faucet hole is smaller.
Have a nice evening,
Seth
August 22, 2006 at 7:17 pm #6820John Cristina
MemberSeth,
We cut all the pieces with two passes then remove the waste at the end. First pass removes 95% of the depth then we kick up the speed on the second pass. Using this method “onion skin” we have been able to cut some relatively small parts with no movement. Took us a while to get a process down but finally got it. We were cutting at 450 IPM but after a few sheet and the bit started getting dull it would break a little sooner than we wanted. By going to 420 we get quite a bit of cutting from it. We tried cutting slower with one pass but the chip load was higher and we got more movement even though we have a 50HP pump. When we cut 3CM now thats a whole nother ball game.
August 22, 2006 at 10:31 pm #6825Andy Graves
KeymasterJohn,
You cut all the parts nested on the sheet with the first pass at 420 ipm and 95% depth and then recut all the parts at full depth but increase the speed to 450 ipm
Doesn’t that mean if I can cut the all the same material at 275 ipm, this process would be faster.
Just curious.
What is the average two sheet job time? Mine is about 6-8 minutes.
August 23, 2006 at 5:08 am #6832Matt Kraft
MemberWe use a 1/4″ upcut spiral @ 250ipm. Could probably run it faster, but the machine only runs for about 4 hours most days, so it really isn’t a constraint on production. If we had more work, speed and optimization might become more of an issue.
Andy,
That seems really fast for two sheet cutting. If I nest everything, sometimes it takes 10 minutes to cut one sheet….
I will have to time one out today.
August 23, 2006 at 6:28 am #6834John Cristina
MemberWe tried cutting in one pass but we were getting movement, too much cutting pressure. so using 2 passes works well with no movement. We can one pass large pieces, but for the CAD it is easier just to set one program up, copy it and use a different final depth. Mind you this method is not set in stone, we try some different stuff on occasion. Always open to suggestions.
3CM
250 IPM 3/4″ rough cut up spiral 18000RPM First Pass
350 IPM 3/4″ finish up spiral 18000RPM Second Pass
August 23, 2006 at 8:46 am #6839Andy Graves
KeymasterMatt,
Are you cutting every single piece for the countertops. All the edges are included?
August 23, 2006 at 11:19 am #6843Matt Kraft
MemberYes Andy.
When I program a job, all build up edge pieces (1″ wide double stack), loose splashes (with seams marked if necessary), trivets, cutting boards, cooktop corner blocks, warranty color match piece, anything else needed for job is in the program. Scribe strips for cove, also.
It is easier to do it that way, so that everything is accounted for. Too many times somebody forgets to rip something on the saw before it goes to the CNC or after, or when the job is finished, you are digging through the dumpster finding a piece for warranty purposes or splash that they forgot.
More work for me, less work for the guys, like always……
August 23, 2006 at 1:30 pm #6851Andy Graves
Amen to that. I feel like you just explained my job.
August 23, 2006 at 3:27 pm #6853John Cristina
MemberMatt,
We do the same thing. The part I like the best is that it takes a lot of the thinking out of the shop and keeps it in the office. My CAD guy has a master template with preset corner blocks, build up, accessories, etc that he can just drag into the drawing when all the main pieces are laid on the sheets. It works well for us. Like Andy said as far as the work is concerned but it makes the shop much faster.
August 23, 2006 at 3:45 pm #6855Seth Emery
MemberJohn,
Thanks for the response. Not having to worry about parts moving, that would be nice. Our operator has to stop the machine after each build-up is routed, remove it, then proceed with the rest of the program. The two passes is something to consider.
Seth
August 23, 2006 at 5:20 pm #6858John Cristina
MemberWe had to do that in the begining too. What we do now is called onion skinning. On your first pass cut all but the last .04. Starting points dont matter here. The second pass cut all the way thru now is where starting points come into play. We can cut perfect 1″ strips all day and if your start point is right it will move but away from the bit after it is cut and wont get any damage. Call me if you have any questions
(239) 334-1151
August 24, 2006 at 11:36 pm #6893Andy Graves
KeymasterI single cut everything at about 275 ipm. I cut clockwise starting with the outside pieces first. Then I cut the small pieces away from the larger and work my way to the center of the material. I rarely have a piece move and I think I save a ton of time only cutting the piece one time.
Are there any advantages that I am not seeing, cutting the pieces twice?
275 ipm
18000 rpm
3/8″ triple flute helix upcut bit
clockwise around inside and outside of parts.
