August 9, 2008 at 12:54 am #2785Lenny EMember
Andy and Linda,
Thanks for all the hard work on the Lumistone ad. It looks great. Thanks for allowing us the opportunity to support FabNet.
B Rgds,
Lenny
August 9, 2008 at 12:57 am #42197Andy GravesKeymasterHowdy Lenny. No problem at all. Glad to see we got the ad working the way you like. It’s pretty cool the way it actually shows how it glows.
Thanks for participating and thanks for supporting the FabNet. Without the support of the vendors and manufacturers, there wouldn’t be the FabNet we all know today.
August 9, 2008 at 6:49 am #42210Jon OlsonMemberHey Lenny In need to rout out 8,000 Letters in Lumistone. Some of the 1 inch letters need to be bent. Any recommendations on the temp and heat times?August 10, 2008 at 10:39 pm #42266Lenny EMemberHi Jon,
I will email the info to you. Thanks for using Lumistone.
B Rgds,
Lenny
August 11, 2008 at 8:14 pm #42306Lenny EMemberHi Jon,
Is this a trick question? You forgot more about T forming than I will most likely ever know.
Sorry, Im still looking for your email addy. Heres my answer-Temps are 320 +/- 20 F. For best results Make sure the sheet surface is 320 F and the interior of the material (middle) is at least 300 F.
Try not to go over 340-345F as its not good for the material (may blister etc). Try not to set your oven above 340-345 also.
Dwell time (heat time) depends on your oven, or platens if you are using them, A good method I found is to place a themocouple in a hole drilled to the midpoint (middle of a sheet) of a sheet, and another on the sheet surface.
Calibrate the time it takes your particular oven to reach 320 surface and 300 midpoint temp. Also check cooling time once the sheet is removed, to give you an idea of working time and how long it has to stay clamped.
Did I pass the test?
Also let me know if you reccomend anything different. Ill go with anything you say, when it comes to T forming, after all, you are one of the worlds foremost masters at that art.
Thanx,
Lenny
August 22, 2008 at 3:40 pm #42761Jon OlsonMemberHey Lenny Sorry I missed this. Good Information. I’ll let you know next week if you passed the test.August 22, 2008 at 4:48 pm #42763Tom MMemberJon, are you still using the Polytherm?
August 23, 2008 at 6:18 am #42792Jon OlsonMemberHello Tom.. Yes. We just purchased another one. I hope to have it installed before the tour . Going to be close. The one we have now I think is sold. Just waiting for the buyer to make sure of the sale. -
