July 16, 2013 at 1:44 pm #6041Andy GravesKeymaster
Here is a job we just completed. Has a raised bar with cove splash and a seamed in sink.
Rather complicated trying to get all the different planes to line up exact, especially in the window.July 16, 2013 at 7:35 pm #75786John ChristensenMemberNice job Andy!!
I like when the cove splash tucks neatly under and behind the self edge of the raised bar. Very neat and tidy.
July 16, 2013 at 8:05 pm #75787VenioMemberAndy , did you used the cove router for the cove ?.
July 16, 2013 at 8:55 pm #75788Steve MehanMemberYes Andy, that does look nice.
July 16, 2013 at 11:49 pm #75790David GerardMembertop shelf work right there!
Andy, do you go out on those installs?Tambura or volcanic ash? we do that color like….lots! love it! Timeless.
July 17, 2013 at 12:04 am #75791Andy GravesKeymasterIt is Tambora.
Yes, I used the cove router on this countertop. We always do.
Thanks for the compliments,
July 17, 2013 at 7:21 am #75793Tom MMemberDid you cove the set back as well? that’s a really nice touch!
July 17, 2013 at 2:25 pm #75794Andy GravesKeymasterPosted By Tom M on 17 Jul 2013 07:21 AM
I am not sure what you are asking. Set back from what?
July 18, 2013 at 4:52 am #75795Steve , NYMemberAndy, I think he is talking about the end of the splash in the last picture. Is it coved ? How do you do this ? With the Betterly coving router ? We do this as well just wondering if you have a faster way.
July 18, 2013 at 7:00 am #75796Tom MMemberWhat Steve NY said. In the last pic above, it looks like the set back splash is coved at the end as well as the face.
July 18, 2013 at 11:39 am #75803Andy GravesKeymasterAh, got it. Yes that end is coved as well. We set it up the same as the other splash. When trying to route with the cove router, you can only go so far. We use a grinding wheel on a drill to shape the rest. Then just sand as normal.
It’s takes some time and patience to get it looking good. Thankfully it’s just that one corner.
Only reason for that end being like that was because the customer wanted the edge to go through and we needed to cover the existing damage to the face of the upper cabinet. She wanted no cabinet repair at all. Turned out OK, but I was a little worried when making the template.
July 18, 2013 at 2:39 pm #75805Steve , NYMemberThe way we do it is run the splash all the way to the end, then clamp a straight edge on the back of the splash with the correct set back for a router and 3/4″ flush trim bit with a bottom bearing. The bearing rides on the end of the top then over the deck till the router hits your straight edge from there it goes straight up to cut the end of the splash off, you now have a 3/8″ cove and no glue lines. Hardly any sanding.
Hope this makes sense.
July 18, 2013 at 3:43 pm #75811John ChristensenMemberMakes sense to me. That is how I would recommend.
July 19, 2013 at 7:35 am #75816Tom MMemberThat’s a good idea. i will have to try that.
July 19, 2013 at 9:55 am #75820Andy GravesKeymasterWe do that as well but really only works on thin backsplash. This end was over an 1 1/2″ so we had to go with plan ‘B’.
