Viewing 1 post (of 1 total)
  • #2823
    2008 Brand New Radial Arm Polisher
    6’ x 5’ x 4’ on skid with brace
     Weight 900 KG or 1984 LBS
     7 ( 8” diameter ) pads come with unit
     Additional 8” diameter pads $ 125.00 each
     ( 4 ) L shaped units go in pored concrete base
     Concrete base is 20” high x 36” x 36”
     220 volt / 3 phase / 60 HZ
     2 Speeds 350 & 700 RPM
     Variable speed inverter available as option
     Allow  4 – 6 weeks for dilivery
    **Picture is not actual item
    **Actual item is brand new
    view at
    http://www.usedstoneequipment.com/detail.asp?id=113
    call Jeff at 616-405-4022
