January 31, 2010 at 4:29 pm #4171Andy GravesKeymaster
I am curious if any of you have made tables with 3/4″ or the 2cm quartz material? We have an opportunity to bid on some tables and wondered if you need to use a plywood subtop to attach the table base or can I attach it directly to the quartz?
February 1, 2010 at 7:27 am #57575Brian StoneMemberPosted By Andy on 31 Jan 2010 04:29 PM
It will depend on the structure that you’re attaching the quartz to.
February 1, 2010 at 7:39 am #57576KCWOODMemberPosted By Brian_Stone on 01 Feb 2010 07:27 AM
I am curious if any of you have made tables with 3/4″ or the 2cm quartz material? We have an opportunity to bid on some tables and wondered if you need to use a plywood subtop to attach the table base or can I attach it directly to the quartz?It will depend on the structure that you’re attaching the quartz to.
Of places I have been, and looked underneath the tables to see how they were attached. I saw some that were loose…. they were mounted with just screws and anchors, but the ones I have seen using plywood as the sub-base… they all looked great. It did look like they used epoxy to bind, and not silicone.
February 1, 2010 at 12:04 pm #57580Andy GravesKeymasterI was concerned without the plywood, it doesn’t seem that they would hold up with just 2cm quartz with an anchor.
Maybe if I hold plywood back from the edge a few inches and bevel the plywood, silicone to quartz and then attach the base, it should last for a long time.
February 1, 2010 at 1:02 pm #57584Brian StoneMemberPosted By Andy on 01 Feb 2010 12:04 PM
That’s what I would do. It’s probably not even necessary to bevel the plywood. I’d also paint the plywood either black or white depending on the color of the base.
February 1, 2010 at 1:36 pm #57587Andy GravesKeymasterGood call with the paint. They are doing a dark brown color, so I might get something that matches and all will look real nice.
Do you have any opinion of how much back from the edge it would need to be so you don’t see the plywood? I would like to make it a bit bigger than the base, but I am not sure I will have access to the exact base dimensions.
February 1, 2010 at 3:04 pm #57590Brian StoneMemberI’d keep it at least 4″ back from the edge.
If you do that and the table is at 36″ and you’re eyes are at 5’6″ you have to be at least 10′ away before you can see the plywood.
February 1, 2010 at 3:10 pm #57591Andy GravesKeymasterThanks for the infor Brian. That sounds like it should work perfect.
February 1, 2010 at 3:16 pm #57592WagsMemberI have seen 1/2″ solid surface tables done the same way. We have done it with quartz a number of times, it works well and you don’t see the wood sub base.
February 2, 2010 at 8:51 am #57607Kevin PaddenMemberAndy – IF you are laminating the outside edge to a build up of 4CM or more – I’d hold the plywood back from the stone AT LEAST 1/4 of an inch…. IF on the other hand, you are only doing a 2CM top – holding the plywood back 4 inches sounds good, but I’d go with only 2 inches, and make SURE that the guy using the screws that will be used to attach the base to the plywood (if you are NOT doing that part) will use ones that will NOT be longer than the thickness of the plywood – somebody else doing THAT part may not be thinking about that factor!!!
hope that helps……kevin
February 24, 2010 at 5:02 pm #58127Ed SautterMemberIs the edge a laminated edge. If so the underply would be recessed in anyways. I’ve seen alot of them like that and you really can’t see any ply at all.
February 24, 2010 at 10:58 pm #58136Andy GravesKeymasterLooks like we are going to do this job with a 4cm edge. I will hold the plywood back from the back of the edge lamination about a 1/4″
Thanks for the input,
