Viewing 2 posts - 1 through 2 (of 2 total)
  • #2951
    Alain Long
    Destiny Dual Spindle CNC Stone Center
             2003
             4 yrs old
             < 10,000 Hours machine hours
             < 500 spindle hours on New spindle
             Easy to learn and operate touch-screen programming & machine control interface *(NO G-code knowledge necessary)
             Capable up to 6cm stone profiling
             “Connect-the-dots” laser template digitizing, or import, & convert standard DXF files
             Create & edit tool paths at the machine; graphic presentation of tool path
             25-position automatic tool changer with retractable cover
             Dial-up remote diagnostics & service connectivity
             Five (5) axis CNC controlled:
    o       Gantry motion, cross-travel motion, spindle raise & lower, saw raise & lower, 360 degree sawing pivot
    o       Shaping Drive System:
    §         Motor: 20 Hp, Variable speed – 0-10,000 RPM, amp load sensing to optimize
    o       Saw:
    §         Maximum blade size: 6 ¼ in. (160 mm) diameter
    §         Arbor size: 25 mm (.98 in.)
    §         Motor: 3 Hp, 3,450 RPM, Amp load sensing to optimize
             Siemens Control Technology
             Air Powered Venturi Vacuum Generator
             50+ industry-standard BT40 (ISO 40) tool holder & random tooling
             All original manuals and software (StoneCAM) included
             Working Table:
    o       6-in. honed granite for precision vacuum pod work-holding
    o       Depth: 5 ft. (1.270 m), Width: 10 ft. (2.540 m), Height: 25 in. (0.508 m)
             Machine Dimensions:
    o       Height: 8 ft. (1.829 m)
    o       Depth: 16 ft. (5.486 m)
    o       Width: 26 ft. (4.572 m)
             Requirements:
    o       Electric
    §         Power supply: 400V, 3 Phase, 60 Hz, 90 Amp
    o       Air:
    §         Line size: 3/8” ID
    §         Pressure: 100 PSI
    §         Volume: 16 SCFM (Continuous)
    o       Water:
    §         Dual 5 GPM @ 45 PSI
    ·        Filtered to 10 Micron (spindle center feed)
    ·        Filtered to 50 Micron (blade and water ring)
    OR
    §         10 GPM @ 45 PSI
    STILL UP AND RUNNING
    SALE PRICE $65,000
    #45779
    Is it still available?
