December 2, 2008 at 6:51 pm #3181Andy GravesKeymaster
Wanted to post a picture of PaperStone Seam using INTEGRA seam adhesive. Worked pretty well and we didn’t go through the top layer of paper. This sample was sanded with the FESTOOL with 80 grit (quick) and then up to 220 and scotchbrite. You can see the seam line, but it really isn’t that noticable. Looks better than I expected.
December 2, 2008 at 9:39 pm #47584Eli PoliteMemberit looks good.
December 3, 2008 at 7:39 am #47594Curt HerrmannMemberNot bad at all!
Curt
December 3, 2008 at 4:47 pm #47607Mike GladstoneMemberAndy,
That looks real good. Did you use SS Adhesive?December 3, 2008 at 6:58 pm #47611Andy GravesKeymasterMike, we used Integra adhesive. I think it is important to get the deck perfectly flat before gluing. The top layer of paper is not that thick so you have to be careful not to sand through while sanding the seam glue.
Super Glue might work well also. I was thinking about pulling the seam with the Paralign and then open them back a bit to squirt in some super glue.
December 4, 2008 at 5:22 am #47618Gene McDonaldMemberAndy, great seam…is that Paperstone or Eco- Top?…Integra and Paperstone dont like to stick around together…but Eco-top and Integra love each other and seem to never want to split up
Mr. Integra Chad..have you got something for Paperstone now???
December 4, 2008 at 11:33 am #47627Andy GravesKeymasterI used the Integra just to try it. Integra says the glue does not stick that great to the Paperstone, but I thought it would be at least as strong as super glue. After that, there aren’t many more choices.
I will be trying EcoTop soon with the Integra glue.
December 4, 2008 at 4:38 pm #47638Gene McDonaldMemberdats what i would like to try Andy..i mean with the biskets and Integra that should be cool….Im gonna try some scrap and date it…and throw it around to see what it takes to break…that would help me out big time if I didnt hafta use that epoxy mix
December 7, 2008 at 5:54 pm #47753Eli PoliteMemberhave you tried epoxy
March 6, 2009 at 10:23 am #50370Paul YonallyMemberNormal
0false
false
falseEN-US
X-NONE
X-NONEMicrosoftInternetExplorer4
<w:LatentStyles DefLockedState="false" DefUnhideWhenUsed="true"
DefSemiHidden=”true” DefQFormat=”false” DefPriority=”99″
LatentStyleCount=”267″>
<w:LsdException Locked="false" Priority="0" SemiHidden="false"
UnhideWhenUsed=”false” QFormat=”true” Name=”Normal”/>
<w:LsdException Locked="false" Priority="9" SemiHidden="false"
UnhideWhenUsed=”false” QFormat=”true” Name=”heading 1″/><w:LsdException Locked="false" Priority="10" SemiHidden="false"
UnhideWhenUsed=”false” QFormat=”true” Name=”Title”/><w:LsdException Locked="false" Priority="11" SemiHidden="false"
UnhideWhenUsed=”false” QFormat=”true” Name=”Subtitle”/>
<w:LsdException Locked="false" Priority="22" SemiHidden="false"
UnhideWhenUsed=”false” QFormat=”true” Name=”Strong”/>
<w:LsdException Locked="false" Priority="20" SemiHidden="false"
UnhideWhenUsed=”false” QFormat=”true” Name=”Emphasis”/>
<w:LsdException Locked="false" Priority="59" SemiHidden="false"
UnhideWhenUsed=”false” Name=”Table Grid”/><w:LsdException Locked="false" Priority="1" SemiHidden="false"
UnhideWhenUsed=”false” QFormat=”true” Name=”No Spacing”/>
<w:LsdException Locked="false" Priority="60" SemiHidden="false"
UnhideWhenUsed=”false” Name=”Light Shading”/>
<w:LsdException Locked="false" Priority="61" SemiHidden="false"
UnhideWhenUsed=”false” Name=”Light List”/>
<w:LsdException Locked="false" Priority="62" SemiHidden="false"
UnhideWhenUsed=”false” Name=”Light Grid”/>
<w:LsdException Locked="false" Priority="63" SemiHidden="false"
UnhideWhenUsed=”false” Name=”Medium Shading 1″/>
<w:LsdException Locked="false" Priority="64" SemiHidden="false"
UnhideWhenUsed=”false” Name=”Medium Shading 2″/>
<w:LsdException Locked="false" Priority="65" SemiHidden="false"
UnhideWhenUsed=”false” Name=”Medium List 1″/>
<w:LsdException Locked="false" Priority="66" SemiHidden="false"
UnhideWhenUsed=”false” Name=”Medium List 2″/>
<w:LsdException Locked="false" Priority="67" SemiHidden="false"
UnhideWhenUsed=”false” Name=”Medium Grid 1″/>
<w:LsdException Locked="false" Priority="68" SemiHidden="false"
UnhideWhenUsed=”false” Name=”Medium Grid 2″/>
<w:LsdException Locked="false" Priority="69" SemiHidden="false"
UnhideWhenUsed=”false” Name=”Medium Grid 3″/>
<w:LsdException Locked="false" Priority="70" SemiHidden="false"
UnhideWhenUsed=”false” Name=”Dark List”/>
<w:LsdException Locked="false" Priority="71" SemiHidden="false"
UnhideWhenUsed=”false” Name=”Colorful Shading”/>
<w:LsdException Locked="false" Priority="72" SemiHidden="false"
UnhideWhenUsed=”false” Name=”Colorful List”/>
<w:LsdException Locked="false" Priority="73" SemiHidden="false"
UnhideWhenUsed=”false” Name=”Colorful Grid”/>
UnhideWhenUsed=”false” Name=”Light Shading Accent 1″/>
UnhideWhenUsed=”false” Name=”Light List Accent 1″/>
UnhideWhenUsed=”false” Name=”Light Grid Accent 1″/>
UnhideWhenUsed=”false” Name=”Medium Shading 1 Accent 1″/>
UnhideWhenUsed=”false” Name=”Medium Shading 2 Accent 1″/>
UnhideWhenUsed=”false” Name=”Medium List 1 Accent 1″/><w:LsdException Locked="false" Priority="34" SemiHidden="false"
UnhideWhenUsed=”false” QFormat=”true” Name=”List Paragraph”/>
<w:LsdException Locked="false" Priority="29" SemiHidden="false"
UnhideWhenUsed=”false” QFormat=”true” Name=”Quote”/>
<w:LsdException Locked="false" Priority="30" SemiHidden="false"
UnhideWhenUsed=”false” QFormat=”true” Name=”Intense Quote”/>
UnhideWhenUsed=”false” Name=”Medium List 2 Accent 1″/>
UnhideWhenUsed=”false” Name=”Medium Grid 1 Accent 1″/>
UnhideWhenUsed=”false” Name=”Medium Grid 2 Accent 1″/>
UnhideWhenUsed=”false” Name=”Medium Grid 3 Accent 1″/>
UnhideWhenUsed=”false” Name=”Dark List Accent 1″/>
UnhideWhenUsed=”false” Name=”Colorful Shading Accent 1″/>
UnhideWhenUsed=”false” Name=”Colorful List Accent 1″/>
UnhideWhenUsed=”false” Name=”Colorful Grid Accent 1″/>
UnhideWhenUsed=”false” Name=”Light Shading Accent 2″/>
UnhideWhenUsed=”false” Name=”Light List Accent 2″/>
UnhideWhenUsed=”false” Name=”Light Grid Accent 2″/>
UnhideWhenUsed=”false” Name=”Medium Shading 1 Accent 2″/>
UnhideWhenUsed=”false” Name=”Medium Shading 2 Accent 2″/>
UnhideWhenUsed=”false” Name=”Medium List 1 Accent 2″/>
UnhideWhenUsed=”false” Name=”Medium List 2 Accent 2″/>
UnhideWhenUsed=”false” Name=”Medium Grid 1 Accent 2″/>
UnhideWhenUsed=”false” Name=”Medium Grid 2 Accent 2″/>
UnhideWhenUsed=”false” Name=”Medium Grid 3 Accent 2″/>
UnhideWhenUsed=”false” Name=”Dark List Accent 2″/>
UnhideWhenUsed=”false” Name=”Colorful Shading Accent 2″/>
UnhideWhenUsed=”false” Name=”Colorful List Accent 2″/>
UnhideWhenUsed=”false” Name=”Colorful Grid Accent 2″/>
UnhideWhenUsed=”false” Name=”Light Shading Accent 3″/>
UnhideWhenUsed=”false” Name=”Light List Accent 3″/>
UnhideWhenUsed=”false” Name=”Light Grid Accent 3″/>
UnhideWhenUsed=”false” Name=”Medium Shading 1 Accent 3″/>
UnhideWhenUsed=”false” Name=”Medium Shading 2 Accent 3″/>
UnhideWhenUsed=”false” Name=”Medium List 1 Accent 3″/>
UnhideWhenUsed=”false” Name=”Medium List 2 Accent 3″/>
UnhideWhenUsed=”false” Name=”Medium Grid 1 Accent 3″/>
UnhideWhenUsed=”false” Name=”Medium Grid 2 Accent 3″/>
UnhideWhenUsed=”false” Name=”Medium Grid 3 Accent 3″/>
UnhideWhenUsed=”false” Name=”Dark List Accent 3″/>
UnhideWhenUsed=”false” Name=”Colorful Shading Accent 3″/>
UnhideWhenUsed=”false” Name=”Colorful List Accent 3″/>
UnhideWhenUsed=”false” Name=”Colorful Grid Accent 3″/>
UnhideWhenUsed=”false” Name=”Light Shading Accent 4″/>
UnhideWhenUsed=”false” Name=”Light List Accent 4″/>
UnhideWhenUsed=”false” Name=”Light Grid Accent 4″/>
UnhideWhenUsed=”false” Name=”Medium Shading 1 Accent 4″/>
UnhideWhenUsed=”false” Name=”Medium Shading 2 Accent 4″/>
UnhideWhenUsed=”false” Name=”Medium List 1 Accent 4″/>
UnhideWhenUsed=”false” Name=”Medium List 2 Accent 4″/>
UnhideWhenUsed=”false” Name=”Medium Grid 1 Accent 4″/>
UnhideWhenUsed=”false” Name=”Medium Grid 2 Accent 4″/>
UnhideWhenUsed=”false” Name=”Medium Grid 3 Accent 4″/>
UnhideWhenUsed=”false” Name=”Dark List Accent 4″/>
UnhideWhenUsed=”false” Name=”Colorful Shading Accent 4″/>
UnhideWhenUsed=”false” Name=”Colorful List Accent 4″/>
UnhideWhenUsed=”false” Name=”Colorful Grid Accent 4″/>
UnhideWhenUsed=”false” Name=”Light Shading Accent 5″/>
UnhideWhenUsed=”false” Name=”Light List Accent 5″/>
UnhideWhenUsed=”false” Name=”Light Grid Accent 5″/>
UnhideWhenUsed=”false” Name=”Medium Shading 1 Accent 5″/>
UnhideWhenUsed=”false” Name=”Medium Shading 2 Accent 5″/>
UnhideWhenUsed=”false” Name=”Medium List 1 Accent 5″/>
UnhideWhenUsed=”false” Name=”Medium List 2 Accent 5″/>
UnhideWhenUsed=”false” Name=”Medium Grid 1 Accent 5″/>
UnhideWhenUsed=”false” Name=”Medium Grid 2 Accent 5″/>
UnhideWhenUsed=”false” Name=”Medium Grid 3 Accent 5″/>
UnhideWhenUsed=”false” Name=”Dark List Accent 5″/>
UnhideWhenUsed=”false” Name=”Colorful Shading Accent 5″/>
UnhideWhenUsed=”false” Name=”Colorful List Accent 5″/>
UnhideWhenUsed=”false” Name=”Colorful Grid Accent 5″/>
UnhideWhenUsed=”false” Name=”Light Shading Accent 6″/>
UnhideWhenUsed=”false” Name=”Light List Accent 6″/>
UnhideWhenUsed=”false” Name=”Light Grid Accent 6″/>
UnhideWhenUsed=”false” Name=”Medium Shading 1 Accent 6″/>
UnhideWhenUsed=”false” Name=”Medium Shading 2 Accent 6″/>
UnhideWhenUsed=”false” Name=”Medium List 1 Accent 6″/>
UnhideWhenUsed=”false” Name=”Medium List 2 Accent 6″/>
UnhideWhenUsed=”false” Name=”Medium Grid 1 Accent 6″/>
UnhideWhenUsed=”false” Name=”Medium Grid 2 Accent 6″/>
UnhideWhenUsed=”false” Name=”Medium Grid 3 Accent 6″/>
UnhideWhenUsed=”false” Name=”Dark List Accent 6″/>
UnhideWhenUsed=”false” Name=”Colorful Shading Accent 6″/>
UnhideWhenUsed=”false” Name=”Colorful List Accent 6″/>
UnhideWhenUsed=”false” Name=”Colorful Grid Accent 6″/>
<w:LsdException Locked="false" Priority="19" SemiHidden="false"
UnhideWhenUsed=”false” QFormat=”true” Name=”Subtle Emphasis”/>
<w:LsdException Locked="false" Priority="21" SemiHidden="false"
UnhideWhenUsed=”false” QFormat=”true” Name=”Intense Emphasis”/>
<w:LsdException Locked="false" Priority="31" SemiHidden="false"
UnhideWhenUsed=”false” QFormat=”true” Name=”Subtle Reference”/>
<w:LsdException Locked="false" Priority="32" SemiHidden="false"
UnhideWhenUsed=”false” QFormat=”true” Name=”Intense Reference”/>
<w:LsdException Locked="false" Priority="33" SemiHidden="false"
UnhideWhenUsed=”false” QFormat=”true” Name=”Book Title”/><!–
/* Font Definitions */
@font-face
{font-family:”Cambria Math”;
panose-1:2 4 5 3 5 4 6 3 2 4;
mso-font-charset:0;
mso-generic-font-family:roman;
mso-font-pitch:variable;
mso-font-signature:-1610611985 1107304683 0 0 159 0;}
@font-face
{font-family:Calibri;
panose-1:2 15 5 2 2 2 4 3 2 4;
mso-font-charset:0;
mso-generic-font-family:swiss;
mso-font-signature:-1610611985 1073750139 0 0 159 0;}
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{mso-style-unhide:no;
mso-style-qformat:yes;
mso-style-parent:””;
margin:0in;
margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:11.0pt;
font-family:”Calibri”,”sans-serif”;
mso-ascii-font-family:Calibri;
mso-ascii-theme-font:minor-latin;
mso-fareast-font-family:Calibri;
mso-fareast-theme-font:minor-latin;
mso-hansi-font-family:Calibri;
mso-hansi-theme-font:minor-latin;
mso-bidi-font-family:”Times New Roman”;
mso-bidi-theme-font:minor-bidi;}
span.EmailStyle15
{mso-style-type:personal;
mso-style-noshow:yes;
mso-ansi-font-size:11.0pt;
mso-bidi-font-size:11.0pt;
color:windowtext;}
.MsoChpDefault
{mso-style-type:export-only;
mso-default-props:yes;
@page Section1
{size:8.5in 11.0in;
margin:1.0in 1.0in 1.0in 1.0in;
mso-header-margin:.5in;
mso-footer-margin:.5in;
mso-paper-source:0;}
div.Section1
{page:Section1;}
table.MsoNormalTable
{mso-style-name:”Table Normal”;
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-priority:99;
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
font-size:11.0pt;
mso-fareast-font-family:”Times New Roman”;
mso-fareast-theme-font:minor-fareast;
mso-hansi-theme-font:minor-latin;}Good Day to all,
I tell everyone that fabricates PaperStone that they are pioneers. I like to compare PaperStone fabrication to
the early days of solid surface fabrication.
I think we have just started to really find out what you can do with
this type of product. I think with skill
repairs may some day be done just like you would with solid surface. I was working with a new shop yesterday with
a demo with PaperStone and we tried something that maybe a first. On seaming I have always instructed to have a
little adhesive bead on the seam and to razor blade off the excess adhesive as
it starts to set up. On a recent demo I
had one fabricator really scrape the excess after it was dried which really
helped with sanding time on the seam.
Yesterday on the fabricator asked if we could just wipe the seam line
down with acetone to remove the excess adhesive after it started to set
up. I have to say it work great for this
one experiment. If this will work good
with PaperStone I can see field seams being done without any sanding. I have told my fabricators to not sand within
a foot of a field seam as you will have to sand down the adhesive. If this will work I say you can have all your
sanding done before install. I think I
will experiment more with this, but I would encourage others also to try it and
share the information.Thank you Paul
