July 30, 2008 at 4:56 pm #2749
Gene McDonald
MemberHey fabricators out there…I know youse saw my grout and mirror inlay How- to -do type thing…basically the same thing goes for coffee beans…
lightweight inlay objects hafta be glued down first or they will float to the top when you do your pour…but I dont know if this interests you but should the need arise to take care of customer…or those coffee shops out there…maybe this can help bring you some work…if youse need it
not sure if people are starting to inlay in Paperstone yet…that usually follows after you get bored with using it regularly…I wish I can thermoform it but it makes this loud cracking noise when ya heat it up
oh yeah the Cashew oil smell is pretty interesting…brings the squirrels in my shopps Kowboy…i know I shoulda mitered the bamboo
one of these days i’ll do a “Coulda bin done easier project” hehehehehe Im still learningJuly 30, 2008 at 5:43 pm #41745Andy Graves
KeymasterHow did you keep the surface flat and level? I would seem that it would be difficult with the paperstone because you have no leeway.
July 31, 2008 at 6:21 am #41779Gene McDonald
MemberDo you mean the other paperstone colors? or the bamboo?
August 1, 2008 at 3:31 pm #41850Andy Graves
KeymasterI appears the face of all the materials are flat. But if you get the paperstone too high, you would sand through the top layer.
Does that make sense?
August 1, 2008 at 5:12 pm #41853Gene McDonald
Memberof course ..I put the samples together first with Glue so it was a 2 x 10 inch piece then I used the Dani clamps to glue up my bamboo scraps…then I laid a 1/8 piece of clear plexi down and allowed for that with the 3/8 inch PS samples on top of the plexi then I did all the inlay work..glue up with tape and clamps with bars to hold flat
use any type of straight to clamp down masking tape over the epoxy so it dont stck to the straight bar…then I think you should have after everything is done sand it up and finish itthis was a display I made to show people the various colors and also not steal my samples…if they want to see the color and get the name just show them the bottom and sign them up a contract
