January 20, 2007 at 2:04 am #687
KeymasterHow much material do leave when “onion skining” parts on the CNC? I do about .004 . Has anyone had any success going less than that?
January 20, 2007 at 7:31 am #13349Seth Emery
MemberGeez Andy. I think .004″ sounds great. We leave .030″.
January 20, 2007 at 12:21 pm #13372Mark Urbaniak
Member.003 here Andy
January 20, 2007 at 12:51 pm #13381Shane Barker
Member.020, and we don’t have any problems with this amount. If we are cutting something really small I may go more and then do a second pass.
January 20, 2007 at 6:09 pm #13400Andy Graves
KeymasterIt will stay attached at .004 but you have to sand the remaining off. I will try the .003 and see if it will just fall off.
January 20, 2007 at 8:19 pm #13405Mark Urbaniak
Memberi just use a trim router with a lamitate straight bit , just flip the part over ,poke thru, your good to go
January 22, 2007 at 9:33 am #13483Shane Barker
MemberThe thickness of our MDF spoil board changes too much from the weather to cut it that close. We have a routine of flush trimming the excess that works pretty well.
January 23, 2007 at 1:16 am #13515Andy Graves
KeymasterI just cut a top today and set it to .004 and it worked very will. I did set the surface of the mdf spoilboard before I cut. Then all I had to do was lightly sand the edges and it was perfect.
January 23, 2007 at 9:59 am #13523Shane Barker
MemberIf we were to touch off the spoil board just before cutting I could see the .004 working but we usually only touch off when we change tools. It is amazing how much our spoil board changes in thickness from the weather.
March 19, 2007 at 6:51 pm #16719Travis Harper
Membergetting ready to buy a cnc…. hmmm… what is onion skinning anyway. I think you are saying you dont go all the way through the material but not sur.
March 19, 2007 at 10:36 pm #16744Shane Barker
MemberThat’s exactly right Travis, by not cutting through you don’t breach the vacuum and the parts are still connected and stay in place better. All this is done by leaving a thin skin of the material otherwise known as an onion skin.
