All,
Our R&D dept has made some progress with the rodding adhesive we are working on for stone fabrication. We are at a point now where we need to know how important the cure speed is as it may be possible to produce an epoxy that will work for Rodding and Lamination. The rub is, finding a single cure speed that will work for both applications.
I have been told that a 15 minute cure for the rodding adhesive would be great. Could we stretch that out any?
Thanks in advance for your replies.
Chad
Chad, for the most part our rodding would be done on site after the tops are installed, so the faster the cure the better. But we are not the norm, so not sure it matters in this case.
Hi Chad,
How about developing an adhesive for rodding that will set up under water .
I would like to try cutting the rodding grooves on the CNC, pause the machine
for 5 minutes, glue in the rods then let the router continue its job.
The rods would be corrosion resistant of course, stainless or fiberglass and the
adhesive would have to set up under water.
No breakage taking tops with big holes in them off the the CNC!
Hi Chad,
Mr. Fowler, very impressive plant ! Now that’s what I call fabricating !
Because these cookies are strictly necessary to deliver the website, refusing them will have impact how our site functions. You always can block or delete cookies by changing your browser settings and force blocking all cookies on this website. But this will always prompt you to accept/refuse cookies when revisiting our site.
Google Webfont Settings:
Google Map Settings:
Google reCaptcha Settings:
