December 7, 2006 at 8:30 am #480
Chris vt
MemberWondering if anyone might have some vector artwork of marine corp sargent stripes and marine corp eagle globe and anchor badge they would be willing to share.I would be willing to trade images as well.I was also trying to find an image of a Huey or Cobra helicopter.This is a bit of a last minute project for friend.
Thanks for any help.December 7, 2006 at 9:20 am #10939KCWOOD
MemberChrisq…. I may can help you out. What exactly are you asking for,? prints, copies? A lot of artwork you can find on the web. I know a guy that has a lot of that material.
December 7, 2006 at 9:44 am #10941Chris vt
MemberI need actual vector data like an EPS AI or DXF of the images I mentioned so I can engrave some corian.I have been searching the web for free stuff wtih little success any links would be welcome.We have a large data base of vector images just not what I need.Thanks for the help.
December 7, 2006 at 9:45 am #10942Tom M
MemberChrisq,
I can check my Corel disks. There are usually military vector based images, but I don’t know how accurate.Tom
December 7, 2006 at 10:08 am #10943Chris vt
MemberThanks I would appreciate that.I can correct any flaws if you find something.I had Corel loaded for a long time I will try and find it there was a large library of images with that program.
December 7, 2006 at 10:09 am #10944Tom M
MemberDecember 7, 2006 at 10:11 am #10945Tom M
Memberthere was a large library of images with that programI remember, in particular, some great vector line art that included helicopters and artillary, but it doesn’t seem to be on version 9, which I have at work. I will check v. 12 when I get home, tonight.
December 7, 2006 at 10:15 am #10946December 7, 2006 at 10:42 am #10952Chris vt
MemberI have ver 7 and it appaers some of the files associated with it are not there for whatever reason.Thanks I will check out the links you posted.
December 7, 2006 at 12:16 pm #10970December 7, 2006 at 12:21 pm #10971Tom M
MemberHere is a page showing rank insignias.
If you need to have any raster images vectorized, I might be able to help, but I think Shane or Mory would be the best for scanning and tracing these.Tom
December 7, 2006 at 4:20 pm #10985Andy Graves
KeymasterThe new Adobe Illustrator has a way to trace jpeg and tiff images and put them in vector format. Corel has a trace program but I don’t know how well it works.
December 7, 2006 at 8:32 pm #10999Tom M
MemberCorel’s OCR Trace program is not bad, but works best with
outline.
Someone here has ArtCAM. I think that might be the best.Tom
December 8, 2006 at 5:53 am #11004Chris vt
MemberWe have Artcam however I have found the results of the bitmap to vector function limited. In the past I have had the best success simply biulding my vectors on top of the bitmap image.Maybe I’m not setting up the trace function just right.I have posted on the Artcam forum before about what type of results I should expect from the trace command with few answers back.Perhaps I will post the question about the trace command there again.Thanks for all the timely responses much appreciated.
