January 13, 2007 at 6:57 pm #641
Seth Emery
MemberLinks to faucet specs and cooking unit specs have been added to the CAD/DXF Library page. Please let me know if there are any other manufacturers or items that you would like to see listed.
Have a nice day,
SethJanuary 14, 2007 at 1:16 am #12910Andy Graves
KeymasterThanks Seth, Looks real good. Amazing how many specs and manufacturers are out there.
January 14, 2007 at 7:42 pm #12944Seth Emery
MemberThanks for the compliment Andy, and thanks also for the opportunity. There are quite a few manufacturers out there, and sometimes it is hard to find their websites when doing a search. A lot of times you just end up getting links to faucet depots instead of the actual manufacturer. I occassionally run across a faucet that is listed on the work order that the specs can’t be found for online, and we have to have the actual faucet delivered to us or the specs faxed to us. If the contractor/customer would just have the faucet there for the template, it would make life easier for everyone.
Do you drill/rout your faucet holes at the jobsite or in the shop? We rout all of the faucet holes for vanities in the shop, but with kitchen countertops we frequently drill them at the jobsite. We have ran into problems with window sills sticking out too far, and with customers that wanted their sprayers/etc. positioned differently than we routed them. I will sometimes rout the faucet holes in the shop when there is no wall on the other side of the sink (peninsula or island) or when there is plenty of space behind the sink (unusually narrow sink or sink at a 45 deg. inside corner).
Have a nice evening,
SethJanuary 14, 2007 at 7:48 pm #12945Andy Graves
KeymasterWe drill all bathroom faucets and we never drill kitchen because the customer never know what they want.
January 14, 2007 at 8:12 pm #12950Seth Emery
MemberYeah, sounds a lot like we do. Although, with granite and engineered stone, we drill or have the holes drilled as often as possible before going to the jobsite. It is a lot easier to have our supplier or, now that we are starting to fabricate our own, fabricator drill the holes in the shop than to set up to drill them outside at the jobsite.
January 15, 2007 at 6:36 pm #12993Mark Urbaniak
MemberWe drill all faucet holes in shop…….We tell them to have Sink, Fauet,CookTop,Ect, on site at time of template. Or job will not go onto the cnc till we have them in shop……I know it sounds hardcore…but it works…sometimes it can buy you a little time when your busy….LOL
January 15, 2007 at 10:12 pm #13000Wade Stein
MemberSeth
When I try to look up the cad files for drainboards,misc. and switch plates all I come up with is the T-Rex. Not sure what I am doing wrong. On the sink files which line are you using when cutting out sink hole.
Wade
January 17, 2007 at 5:57 pm #13091Seth Emery
MemberThanks for the responses.
MUrban,
It would be nice if the market here was good enough to make those demands, although I don’t have the authority to do so. Glad to hear you must be busy enough.
Wade,
The T-Rex is the only non-sink cutout file that users have donated. It would be great to see some more. About the sinks – are certain lines showing up as dashed lines? These normally represent the flanges. Which files are you talking about specifically? If there are two solid lines, this usually means that the manufacturer gives two options – one for showing a stainless (or whatever sink material) reveal and one for the sink edge being flush with the countertop. I never, well rarely, cut out an undermount sink without first verifying the cutout with the actual sink and template that was sent from the manufacturer.
SethJanuary 17, 2007 at 9:03 pm #13102Wade Stein
MemberTHANKS SETH FOR THE INFO.WADE
January 17, 2007 at 9:26 pm #13108Tom M
MemberSeth, here’s a thought – no, make that two:Corel has vector based images on that come packaged with the product. There isn’t a very high percentage of usable stuff, but the volume you get does yield some worthwhile inlays, borders, etc. I wonder if we could get permission to place theirs that would translate well to solid surface inlay work.
Other than those, I am surprisingly bereft of these types of files. Does anyone have some images that could be uploaded?
Second, I’ve always wondered why, when so many kitchen designers have graphics backgrounds, that someone doesn’t hold a contest for great iinlay designs, that could be separated from easy to hard to actually produce (overlapping colors, etc.)?
January 18, 2007 at 12:15 am #13120Andy Graves
KeymasterMY BAD
I have the files for drain board and other stuff. I will try to post them shortly. Got some other stuff to finish first, but I will get to it. Maybe I will send them to Seth to upload if he gets a chance.
