August 19, 2009 at 5:15 am #3851Norm WaltersMember
I have a customer that has hard water stains near the faucet on her Zodiaq top. She has tried some readily available supermarket type products on it to no avail, any suggestions?
August 19, 2009 at 7:11 am #53742Brian StoneMemberUse a razor blade to scrape off the buildup.
Start with a new blade. Hold it perpendicular to the deck of the counter top. And drag it along the buildup until it is all scraped off. I usually spray some type of quartz approved cleaner on it before I start. It doesn’t help with the stain but it seems to help contain all of the stuff that gets scraped off…like wet sanding.
August 19, 2009 at 8:44 am #53746Un-AuthorizedMemberNorm:
I was told to use a black Alpha buff pad wet to dry to remove hard water stains on granite, but that technique would certainly burn the polyester in quartz. It might work if done slowly and with lots of water.
I like the scraping with the razor blade idea to start. Hit it with some of Dani’s Estone Restorer.
August 19, 2009 at 11:21 am #53751Brian StoneMemberOh yeah, if she tries any more cleaning products make sure to let her know that she needs to clean the area thoroughly with soap and water after she is done. Some of those products will eat the polyester binder and then you will have bigger problems.
August 19, 2009 at 11:23 am #53752Brian StoneMemberIt doesn’t mention hard water buildup but you may also want to direct the customer here.
August 19, 2009 at 1:02 pm #53756Karl CrooksMemberPosted By Brian_Stone on 19 Aug 2009 07:11 AM
Use a razor blade to scrape off the buildup.Start with a new blade. Hold it perpendicular to the deck of the counter top. And drag it along the buildup until it is all scraped off. I usually spray some type of quartz approved cleaner on it before I start. It doesn’t help with the stain but it seems to help contain all of the stuff that gets scraped off…like wet sanding.
+ 1 …… This works good !
August 19, 2009 at 3:04 pm #53757Norm WaltersMemberThanks, I ‘ll suggest the razor blade. I can’t believe I didn’t think of that, gettin’ old.
August 19, 2009 at 4:12 pm #53759Andy GravesKeymasterI used the razor blade and it worked on my countertops. There was a little bit of white haze left, but I just used a little cleaner and it seemed to go away.
August 20, 2009 at 12:13 am #53768Chris YaughnMemberRazor Blade.
I actually have a job now where over the last year and a half, the house keeper has taken the quartz around the faucet down to a mat finish w/ brillo pads due to hard water.
