Viewing 11 posts - 1 through 11 (of 11 total)
  • #5072
    Hi guy’s I cut my first bit of Essa Stone yesterday 20mm thick. Its not that hard I used the festool saw with a diamond blade in it and did it dry. A very neat cut but it chipped out at the end of the cut. Next thing is to get some polishing gear to polish the edge.
    #67858
    20mm is the 3/4″ material, correct?
    Do you think the FESTOOL has the power to cut quartz long term?
    #67862
    Yes Andy it’s 3/4 inch, the festool ate it like butter. I had no idea cutting stone was so easy and dust free, there are a few fab shops that use the festool saws only over here.
    #67867
    What blade are you running on the festool?  I had a blade bored for it once and tried it on Granite and it didn’t get it done.  2cm quartz is a lot easier to cut.  Would love to use the festool on cooktop cutouts on site.
    #67869
    It’s a blade from Norton for granite and tiles stone etc. it has a 22mm hole so fits straight on to the festool. They are about $50 here so you guy’s will get them fairly cheap in the states.
    #67870
    Definatly going to give it a try/ I was using a thicker kerf bridge saw type blade.  The tile blade might just work.
    #67873
    Good to hear it stands up to the added stress of cutting granite.
    #67877
    Any chance you could shoot me a part number .  I am  not familiar with Norton, so I am trying to run them down.
    Did you set the depth just shy of cutting thru or did you cut all the way thru the stone on the first pass.
    #67889
    Jon Olson
    #67892
    The part no is SCERAM-15022 150×22/20 PRO continuous rim.I just set the blade at full depth and it cut through it in no time Chris.
    #67893
    That brings back memories Jon.
