June 18, 2013 at 9:42 am #6015Thad ChartrandMember
Business Closed – All tools/items must go
Fully operational Granite/Quartz fab shop shut down, have received an offer on building and everything must go by Aug 1, 2013. Have pics of all items. If interested, please respond by e-mail to : tchartrand@sbcglobal.net or phone 269-332-7821. Business located in Southwestern Michigan. Will consider bulk price for several items, just send me list and offer.5- 400 ml tubes- Integra Adhesives Roding Compound – $20 ea = $100
74- Mixing Tips – $50
½ Gallon Polyesters Superior Adhesive – $30
1- Glue Gun – $15
2- Dremil’s – $30ea = $60
12- Akemi Color Pigment tubes – $25 for all
8- K-bond coloring paste 2oz bottles – $25 for all
1- Box of Stir Sticks – $5
1- Box of Rubber Gloves – $5
1- Can of Ager Color Enhancer/ Sealer – $10
1- quart can of Bellinzoni Clear & Black Edge Wax – $10ea = $20
1- can of each – Dia-glo Light & Dark Polishing Powder – $10 ea = $20
Misc Cleaning Supplies – Lacquer Thinner, Acetone – $20
10- suction cups for StonePro Sink Saver w/ 84” aluminum bars -$250
1 – T31 Sink Anchor system w/pneumatic grinder – $175
1 – Makita 4” variable speed grinder w/water feed – $150
Core Bits 12 Different Sizes – $300
Misc.3” & 4” Back-up Pads – $25
7- Various 3”, 4”, 5” Cup Wheels All grits & Kinds – $100
11- various sizes and types of granite Cut- Off Wheels – $125
1- 5” Contour Wheel – $50
1- Sink Clean Up Wheel – $60
10 – various grits & sizes of Grinding wheels – $25
3- Alpha Profile Wheels – ¼”, 3/8” and 5/8” radius – $50 ea = $150
1- Stonelux Repair case/Kit – $750
1 – New Diarex Magnum 3 Edge Profiler W/ Hydro Float W/ Half Bull nose, Full Bull nose & Bevel profile tools – $2,500
2- Heat Guns – $20 ea = $40
2- Hercules A-Frame shop cart – $400 ea = $800
1- 7’ steel fabrication Table w/ casters – $220
2- Hercules Remnant Carts – $150
1 – Imer Combi 250 V Tile Saw – $500
1 – Milwaukee 7” Sander/ Grinder – $75
1- Air Hand Polishers – Alpha – $75
2 – Flex Right angle polisher w/ center water feed – $50 ea = $100
5- Various lengths Garden Hoses – $40
1 – 18” Pedestal Fan – $100
2- Hercules Fabrication Support Stands – $50 = $100
1- Abaco Model 50 Heavy duty Slab Lifters – $250
11- Steel Remnant Racks – $200 ea = $2,200
1- Hercules Tall A frame Slab Rack – $125
1- Telescopic Slab Boom – $500
1- Weha Transport rack – double sided 48 x 84 – $800
10- Steel Adjustable Shelves – 14’ tall – $1,500
2 – sets of Stone Pro Carry Clamps – $150 ea = $300
1 – set of Abaco Carry Clamps – $150
2 – Abaco Seam Setter M-22 – $150 ea = $300
1 – Caterpillar 50 – 5000# LP fork truck – $4,800
1-Weha One Side 72 x 48 Transport Rack – $500
1 – Hercules 3 wheeled slab dolly – $125
Several misc length extension cords – $25
Manual chemical concepts glue gun – $30
15 – misc colors of adhesives for seaming – $20
1 – box of clear silicone – $50
1 – box of transleucent silicone – $50
3 – caulk guns – 10.5 oz – $15
1 – large caulk gun – $10
Misc blue and masking tapes, pencils, tape measures – $5
1 – Hysol Hot melt glue gun and glue – $250
1 – framing square – $5
1 – each 48”, 30”, 18” levels – $50
2 – sets of suction cups for seaming solid Surface – $80 = $160
1 – Stone Pro Seam setter for stone – $100
1 – box of approx 20 Dishwasher mounting brackets – $75
2 – Shop Vac vacuums – $25
1 – seam kit full of tools, adhesives and items used to install seams in stone tops and sink mounting tools – $40
1 – case of various length screws – $10
1 – case of sink mounting brackets, bolts and nuts – $10
1 – shelf of misc sealers, solvents, and cleaners – $25
1 – shelf of misc types of c-clamps – $50
1 – set of saw horses – $15
2 – sets of hole saws – $20ea = $40
1 – Bosch Jigsaw – $75
1 – Milwaukee 7” grinder/sander – $75
1 – tool box filled with 2 – Makita grinders with core bits, cut-off wheels, cup wheels, dry polishing pads, Velcro back-up pads – $300
2 – flashlights – $5ea = $40
1 – Bosch corded drill – $75
1 – 7” Skil saw – $50
1 – 5 gallon bucket of 2” spring clamps – $25Solid Surface Tools/equipment
1- Hitachi C8FB2 Mitre Saw – $125
1- Pinske Edge Aluminum 90 degree square – $100
1- Pinske Edge Aluminum 1 1/2” radius template – $100
2 – 45 degree Aluminum Templates – $100 ea = $200
1- Pinske Edge Air Circle Compass Kit – $125
1- Pinske Edge sink & cooktop cutout template – $125
300 – 2” spring clamps – $2 ea = $600
2- sets of 8” Pinkse Edge suction cups in metal cases – $125 ea = $250
1- Mixpac DP-400 Pneumatic glue gun – Like new – $200
1- Mixpac DP-200 Pneumatic glue gun – $150
1- Mixpac DM-200 manual glue gun – $100
2- cases of various router bits, insert bits (approx 40/case) – $150 ea = $300
1- Delta 12” disc sander w/ extra discs – $100
1- Corian 50ml manual glue gun & 51 mini glue sticks – $30
1- 2” C-Clamp – $5
1- 3” C-Clamp – $7
2- #310 Laminate routers – $75 ea = $150
1- Bosch 1hp fixed base router – $125
6- 10” carbide triple chip table saw blades – 5 @ $40 = $200
5- 8” saw blades for Mitre saws – $20 ea = $100
1- Powermatic #27 – 5hp 7,000 RPM shaper – $1,800
1- Delta #36-839 Multi speed power feeder – $600
1- Delta 5hp 10”table saw w/52” Beismeyer Fence system – $1,750
1- Complete Pinkse kit for coved backsplash – Cove shaper cutter, Cove backsplash jig,
Porter cable 3hp cove router, Approx 45 clamps, 14 insert bits, 1- insert bit tool, 1- 1/8”
router bit, Rabbit end stop template, special Dado router base, 60 stop clamps – $2,000
1- Pinske Edge 144” power stand table – $175
1- Pinske Edge 96” power stand table – $150
1- Pinske Edge Shower Drain kit – $150
1- Pinske Edge Repair kit – $150
1- Porter Cable 6” orbital sanding kit w/sandpaper – $100
shelving, sheet goods racking & Corian/LG Remnants- $750Also have over 200 Granite, Marble and Quartz remnants for $25/ pc. If interested, I can send a list of colors and sizes.
