October 12, 2010 at 2:30 am #4681Eric BeckMember
Hi All
I am interested in finding out in what ways can mines excavate stone.I am aware of using TNT to blast the rock off but I was wondering if anybody else knows any other ways of dong it. And if you do would you be able to explain the process or refer to a place where I can read up on it a bit more.
Thanks a lot
P.S. I am new to the natural stone so please take that in to count.
October 12, 2010 at 3:14 am #63248Andy GravesKeymasterCall the Marble Institute of America. The will be able to help you. http://www.marble-institute.com
October 12, 2010 at 11:44 am #63265Jeff HandleyMemberBigZ,
Here is a good informational link to get you statred. http://quarriesandbeyond.org/quarry_industry.html#links
This MIA member company offers a unique alternative to TNT. http://www.dexpan.com
Here is my favorite informational link about quarries : http://www.virtualquarry.co.uk/
I found it while looking for Webby nominated sites.Jeff
MIAOctober 12, 2010 at 12:50 pm #63267Jon OlsonMemberIs there a way to replace mountain tops?
October 12, 2010 at 3:46 pm #63269Gene McDonaldMemberStack back up the stone slabs smarty guy you
October 12, 2010 at 5:15 pm #63271Un-AuthorizedMemberPosted By Jon Olson on 12 Oct 2010 12:50 PM
Is there a way to replace mountain tops?Jon:
Unfortunately, no. Once they rip the top off a mountain to excavate bauxite from which they extract the aluminum tryhydrate, the filler in solid surface, it doesn’t usually go back the same.
October 13, 2010 at 12:11 am #63279Tom MMemberHeh, good one.
Not quite the same amount, though.
October 14, 2010 at 2:35 pm #63312Mark MeriauxMemberPosted By Tom M on 13 Oct 2010 12:11 AM
Heh, good one.
You’re correct Tom. Since Bauxite must be refined before use, larger volumes of earth and rock must be disturbed in the mining process. Additionally, large quantities of power are used in the refining process.
October 14, 2010 at 2:43 pm #63314Mark MeriauxMemberBack to the original post……in the extraction of cubic/block materials, blasting is getting less commonplace. Most modern quarrys drill vertically and horizontally, then use diamond wires (like a chainsaw) to separate large blocks. Then a “pillow” of earth and rock is constructed below the wall. It is knocked over (with explosives or hydraulic pillows), or pulled over with large excavators. Once separated, the large block is further processed into smaller blocks that can be loaded and transported to slab and tile factories.
October 14, 2010 at 3:14 pm #63316Tom MMemberSo, Mark, you are claiming that there is a greater area of land removed for solid surface than stone to make a comparable amount of sheetgoods used for countertops?
I’d like to see some verifiable data on that.
October 14, 2010 at 3:26 pm #63318Mark MeriauxMemberNot in any of my posts did I make such a claim.
I would be interested in that type of study. Between the extraction, raw materials refinement, and end-use manufacturing. Total raw materials and natural resources (energy spent) in the overall process would be an interesting comparison.
I have no idea even what the direct percentage yield from stone quarries are, but ideally what stone is not used in it’s raw extracted volume (tiles or slabs) can conceivably be used as crushed aggregate for a number of other processes. I doubt that ANY quarry is ideal.
October 14, 2010 at 3:33 pm #63320Mark MeriauxMemberBack on topic again…….there was an interesting article about quarrying in last month’s Stone World Magazine (Sept ’10, starting on page 58):
October 14, 2010 at 3:39 pm #63321Tom MMemberMark, thank you for the clarification.
I’m not belittling your statement either. I would be interested in a study as well, but the stone part would seem to be much easier to quantify. You have the slab cut from the block, less the waste from block to polish.
The bauxite to sheet would be a nightmare to figure with all the other extractions going for the multitude of products the alumina gets used for. Then you would need, in fairness, to add the other elements which have their own environmental impact, but are not included in simple bauxite extraction.
A daunting process.
October 14, 2010 at 3:42 pm #63322Mark MeriauxMemberA daunting process indeed.
October 19, 2010 at 9:01 am #63403Mark MeriauxMemberHere’s a cool video posted by Michael Reis at Stone World Magazine.
It shows the stone “shelf” being pulled over onto a pillow of dirt by large excavators… -
