June 3, 2013 at 12:56 pm #6004Andy GravesKeymaster
Anyone use corrugated plastic to space countertops? I have seen it at a trade show but can’t remember what the name of the material.
I would like to try on a few jobs we do to save weight and cost.Thanks in advance,AndyJune 3, 2013 at 4:56 pm #75537Sue TurnerMemberAndy are you talking about Templast? We used it for making templets. We got it from the suppliers of Dovae SS. It looks like corrugated cardboard only a white opaque color.
June 4, 2013 at 7:37 pm #75550Andy GravesKeymasterMaybe, but it was extremely rigid. You could stand on it without it compressing. I’ll check that out and see.
June 17, 2013 at 6:39 am #75618Matt KraftMemberAndy,
That corrugated material should be available in multiple thicknesses. We make digital templates exclusively for our kitchen dept and have for some time, but we still buy some of the 4mm corrugated plastic in 4′ x 8′ sheets for our cultured marble dept. Even if we make a digital template for that dept, I’ll cut them a physical template.
We buy it from a sign supply company. I’d check with them. Same guys that sell acrylic sheeting and the like. I’ve seen some of the stuff that is like 5/8″ or 3/4″ thick, they can probably get it for you.
Matt
June 18, 2013 at 2:08 pm #75622Andy GravesKeymasterDo you think it is rigid enough to support a countertop?
June 21, 2013 at 11:41 am #75629Matt KraftMemberAndy,
You could park cars on that stuff at the proper thickness.But the cost goes up exponentially if I recall.MattJune 21, 2013 at 1:51 pm #75630Andy GravesKeymasterI’ll check it out.
June 24, 2013 at 5:21 am #75633June 24, 2013 at 9:39 am #75634John CristinaMembertemplast is different than something like a honeycomb. there are a few companies that manufacture the stuff using different plastics and other materials and colors. I have used some that was clear for doing backlight work.
June 25, 2013 at 7:06 am #75635Tom MMemberThere used to be a product made by a company called the Norfield Corporation. It was called Norcore. 1/8″ flat plastic extruded to 3/4″ thick. They had other sizes available as well. It was used as a lightweight substrate for trains, planes, etc. MDF board was at the outside edges, which was all held together with contact cement on backing sheet. We covered it in laminate and postformed the front edge.
June 25, 2013 at 9:41 am #75637Andy GravesKeymasterThe stuff I remember seeing was in the solid surface magazine but I can’t find it for the life of me, I even had a box of samples and I threw those away during a cleaning session.
