August 8, 2008 at 1:11 pm #2782Reuben Hoff IIIMember
I have been thinking a lot about this green stuff. I may never be a green fabricator of products anytime soon, but got to thinking about landfill stuff. I pitch a fair amount of particle board, MDF scraps and wood scraps in the trash.
i was wondering about setting up a burn pit by the shop instead of pitching it buring it. I guess my question is can you use that to fertilize the garden or give it to people to put in there composte?
Gotta be something to help reduce the cities trips to the landfill.Maybe should put this in the green section, but it really isn’t a material. Guess it really isn’t about a countertop really either is it.
August 8, 2008 at 1:26 pm #42160David GerardMemberReuben, we save all the hardwood scraps and a friend who takes them home for his wood stove. The mdf and PB are ripped into 3 strips for lam build up the rest ends up in very small pieces, and like you we can torch em.
August 8, 2008 at 2:06 pm #42163Andy GravesKeymasterI didn’t think it was a good idea to burn wood with glue in it. Doesn’t it give off toxic fumes?
August 8, 2008 at 2:50 pm #42167Jon OlsonMemberI don’t think its good to burn MDF. Toxic fumesAugust 8, 2008 at 3:10 pm #42168Reuben Hoff IIIMemberUh, wasn’t planning on indoors was gonna do it outdoors, but I suppose if one tried to much at once it would create a problem. Maybe was not as good idea I thought it was.
August 8, 2008 at 3:58 pm #42170Jon OlsonMemberWe use the left over MDF to make glue up blocks. Test sink jigs etc…. How about your local school do they have a wood shop? Good stuff to practice withAugust 9, 2008 at 12:28 am #42195David GerardMemberWith reguard to mdf, I have heard two sides of destroying many things that give off toxic anything. Burn it and it’s fumes, bury it and it’s toxic ground water. A nasa scientist told me if you want to incinerate with little or no toxic fumes , get the fire very very hot and not smoldering, and of course outside.
August 9, 2008 at 2:26 am #42204Lenny EMemberPosted By David G. on 08/09/2008 12:28 AM
With reguard to mdf, I have heard two sides of destroying many things that give off toxic anything. Burn it and it’s fumes, bury it and it’s toxic ground water. A nasa scientist told me if you want to incinerate with little or no toxic fumes , get the fire very very hot and not smoldering, and of course outside.Hi All,
Nevamar and International Paper used to burn thier laminate scraps to generate heat for the boilers. The Towers had scubbers on them to eliminate toxic fumes. Sounds like a win win to me.
Lenny
