April 11, 2007 at 9:03 am #996
Reuben Hoff III
MemberI have seen these in several places and they kinda got me curious. I was wondering if anyone here has used these sink clamps. Look like they could work well, but then again looks can be deceiving. SO if anyone has used them pros or cons would be appreciated.
April 11, 2007 at 9:32 am #18213Sue Turner
MemberReuben we tried these in our shop because we do a lot of neo-angel corner wide bar sinks here in the Hi-Desert. We tried the hot melt sent with the clamps and our own hot melt but it all seamed to release from the clamps with out much presure. We were concerned we would not keep a good glue line so we quit using them. May be we just had a problem with the hot melt glues we tried but we could not get them to hold.
April 11, 2007 at 9:40 am #18214Joe Corlett
MemberReuben:
I have seen the Betterly clamps, but never used them.
I hot melt small wood blocks for positioning, then double up some Dani clamps of the front and back edge of kitchen sinks. With that much pressure, you don’t need to clamp the middle. Obviously the sink isn’t going to bend.
For many years, I just placed a two-ton hydraulic jack on top of each drain hole after positioning.
I’ve never had a failure with either method.
April 11, 2007 at 10:47 am #18219Dani Homrich
MemberNo need to hot melt clamps on the deck to hold your sink, no need to clean hot melt off your clamps after you use them and these clamps will last over 10 years and never pop off when clamped.
April 11, 2007 at 11:01 am #18221DIMIN01
MemberReuben, if you wish to try the Betterly clamps to see if they’ll work in your application, a set will be sent no charge.
April 11, 2007 at 2:17 pm #18231Reuben Hoff III
MemberWow Dave for that statement lets get em on the way and we will even do up a review for the Fab Net.
April 11, 2007 at 2:21 pm #18232Tom M
MemberDani,
Double gluing the Dani Calmp for bowls.
Did you think of that from the start, or after awhile?
April 11, 2007 at 2:43 pm #18234Tim Simkin
MemberConsider it done Reuben.
April 11, 2007 at 3:03 pm #18238Dani Homrich
MemberTom,
Double ringing has always been my procedure for clamping shorter distances to achieve the same clamping pressure as you would with thicker material with the same clamp. The more you open my clamps the more clamping pressure they have. For sinks,1” of material 4” clamp (blue) single, 6” edge clamp (black) with a 6” cove clamp (red) over it, double ringed 8” clamps (orange), and triple ring 12” clamps (purple). Note; the EM6 clamp (black) for edges works great on 1” material when you are clamping edges.
Dani
April 11, 2007 at 3:23 pm #18239Reuben Hoff III
MemberDani,
The EM6 is that a total thickness of 1 1/2″ as in yo are clamping on the 1″ worth of build with the fab method you have talked to me about? I like to do the 2″ stacked edge so for the first layer is only 1″ so the EM6 do not have enough pressure until I add the second layer correct?
April 11, 2007 at 3:59 pm #18240Dani Homrich
MemberReuben,
The EM6 clamp will clamp edges from 1” to 3 1/2“ just fine no need to add more clamping pressure as long as you are getting good squeeze out. Use the CD6 clamp (red) for clamping 3” to 7 1/2”. When you are clamping 1” or 2” the EM6 clamp is the one to use for edges.
Dani
April 11, 2007 at 7:23 pm #18243John Cristina
MemberEvery shop needs some Dani clamps. I have guys that worked in other shops in my area and look at them and laugh. However once they use them and see how fast they are for sinks, large drop edges like skirts, certain seams, etc, they love them. If you look closely in my shop my employees have them in use for all kinds of things. Buy some, you’ll order more.
April 11, 2007 at 8:27 pm #18246Tom M
MemberAgreed John,
Dani clamps are the kind of tool where, once you see them you say “Sure, I could have thought of that “- but you never did.
Well, Dani did, and although there are lots of clamps that do lots of things, there are certain operations where nothing else comes close. I have quite a few of them now, I know I’m getting more.
(and you can quote me on that, Dani)
April 11, 2007 at 8:34 pm #18247Jason Coache
MemberNeroghoutioun. Yesstchem hasgenar. Ooreh pghnikeh.
April 11, 2007 at 8:59 pm #18250Tom M
MemberCould be gaelic, could be klingon, but either way, it’s Greek to me.
