August 28, 2007 at 7:28 am #1556Matt KraftMember
OK, like many of us fabricators, I have no real drafting training, but pretty much always figure out a way to get it done.
The only way I know to draw smooth curves from templated data points is to draw a spline. But my machine can’t cut a spline (3D component). I can get around this sometimes by converting everything to 2D in my CAM program (Toolpath). But I have a tub deck I’m drawing now and I have a gorgeous spline for the curved front edge, but I can’t fillet to the spine or anything.
How do I get that beautiful curve back to something I can work with? Can I convert it to a polyline? It won’t explode.
Please help.
August 28, 2007 at 7:34 am #25597Matt KraftMemberUsing AutoCAD LT in case I didn’t mention.
August 28, 2007 at 7:47 am #25599Tom MMemberMatt,
I’m no AutoCAD expert, but if you send me the files to:
info”at”mathertops.com
and cc to:
musedive”at”comcast.net , I’ll see if I can join the polyline.
You could try to connect the points as a polyline and convert to curves, if AC allows it.
August 28, 2007 at 9:19 am #25608Travis HarperMemberMatt, What templating system are you using ?
August 28, 2007 at 10:31 am #25617Matt KraftMemberWe are using PhotoTop.
I think I may have figured it out, but I’m not sure how I got it done, so if anyone can actually give me the steps to get it accomplished for future reference, that would be great.
Its not cut yet, but I think I am done with the drawing, there is still a chance I can eff it up……
August 28, 2007 at 10:38 am #25620Dennis SchaferMemberYou should draw the curves as a series of polyline arcs rather than a spline. A spline will not fillet to a polyline. However you could run your spline past the edge of a polyline and use the trim command to get a closed shape.
Your machine should cut splines. I use them all the time for engraving, and a lot of sink manufacturers dxf files contain splines rather than arcs in the corners.
August 28, 2007 at 12:14 pm #25635Andy GravesKeymasterAlphaCAM can convert splines to arcs. Then you can fillet them like all other lines and arcs. I am sure AutoCAD has the same feature.
I bet you Seth would know.
August 28, 2007 at 5:22 pm #25673Mike GladstoneMemberMatt,
I’ve got a cad/cam program that I can import your file, join your lines and then export back out to .dxf. You can email the file to me at mdbc@ij.net and I’ll convert it for you.
