July 20, 2008 at 8:50 pm #2702Chris YaughnMember
While adding offsets to a dxf after leaving the jobsite (Job A) , I accidentally saved the file as another job name (Job B). Today I went to pull the file for Job “B”.
Is there anyway to recover the version of Job “B” that existed prior to that mistake? The job is an hour away and I am looking for a way not to have to burn 2 hours and gas to re-shoot the one little part I saved over.
Anybody?
July 20, 2008 at 9:35 pm #41162Seth EmeryMemberChris,
If you have a network set up and do a back-up each evening, you could get the old file from the back-up tape. Does your CAD program create backup files? If so, you may be able to retrieve the “old version” from there if it hasn’t been overwritten by you modifying the “new version”.
Good luck,
SethJuly 20, 2008 at 9:59 pm #41163Chris YaughnMemberSeth,
No network or back-ups here. Just me and a laptop. B/c I have a partner shop do most of our stone fabrication I do very little CAD work. I have the barebones version of turbocad. The painful thing is that the “memory” tab in turbocad shows the thumbnail of the file I need, but when I try to open it it requires the “updated” file which is on a disk that stays in the LT55 pda.
I have a feeling I am going to have a few hours tomorrow to ponder the meaning of life,……
July 20, 2008 at 10:17 pm #41164Andy GravesKeymasterIf you created the file in the PDA and it is on the PDA then isn’t it still on there?
Did you download the file on your PC and then made changes? Seems that it would still be on the memory stick. NO?
July 20, 2008 at 10:22 pm #41165Chris YaughnMemberI pull the memory stick out and access it w/ the laptop. Then back into the pda it goes.
July 21, 2008 at 7:58 am #41168Paul BinghamMemberThe system makes a backup file as you work. If you havn’t made another template since this job you may still have the backup file on the card.
Paul
July 21, 2008 at 8:01 am #41169Paul BinghamMemberFotgot to mention the file name is autosave.
Paul
July 21, 2008 at 9:33 am #41170Gordon ShellMemberPut the SD card in your lapt-top and do a file search for autosave, it will find a ton of files, look for the date and time of the template and your file should be there.
Call me if you don’t find it.
Gordon shel
July 21, 2008 at 10:46 pm #41213Chris YaughnMemberFor some reason my pda wasn’t autosaving. I tried looking the files up but, no go.
No worries. I fixed it the old fashion way (I re-did it). I’ll take an extra second in the future to double check before clicking “OK” to overwrite existing files.
July 22, 2008 at 10:42 am #41226Andy GravesKeymasterPosted By Chris Yaughn on 07/21/2008 10:46 PMFor some reason my pda wasn’t autosaving. I tried looking the files up but, no go.
I have a practice of never saving over the initial digitizing. I always rename it to note a revision. You may want to start doing this not only in case you make a mistake, but you will always have the original to refer back to in case a fabrication error happens.
July 22, 2008 at 9:36 pm #41256Chris YaughnMemberAndy,
That is not a bad idea.
Only problem is my PDA has a habit of…..well…..
uhm…..
.. going microsoft on me.So I hit the save button an awful lot while generating the original file. In this case , however, your protocol would have saved me.
