November 8, 2011 at 7:21 am #5329Michelle GoetzingerMember
I have a possible acid etching ring on an absolute black granite top, made by heavy cleaning agent, do you guys have any recommendations on how to repair?
thanksNovember 8, 2011 at 10:23 am #70017Lenny EMemberHi Michelle ,
Long time no see, how the heck are ya? Im fine and still sucking air and hope you are the same!
3 questions before I reply.
1.) running your hand accross it, can you feel the etch? Can you visibly see it as roughness (disregarding color)?
2.) Did it show up as a white ring? If not what does it look like?
3.) was the top sealed (Im thinking not!). 🙂
November 8, 2011 at 12:23 pm #70024Michelle GoetzingerMemberThe lady said she used shock it clean Xtreme
I am doing great thanks for asking!
1. It is smooth
2. yes it has a milky appearance
3. not sure if it was sealed but most likely not ( was not our install)
Thank you very much for your help.
Michelle
November 8, 2011 at 12:23 pm #70025Michelle GoetzingerMemberThe lady said she used shock it clean Xtreme
1. It is smooth
Michelle
November 8, 2011 at 6:37 pm #70026Lenny EMemberMichelle,
Go over on the stone boards or gardenweb and chat up a lady named “stonegirl” she forgot more about this than I will ever know. If you can’t locate her, read below.
If you can’t feel it, it didn’t severeIy etch the stone. I think that product contains solvents (degreasers) if I am not mistaken. You can try various poltices etc. (Doubt if it works). See http://www.kitchen-counter-tops.net/granite/care-and-cleaning-for-granite-countertops.html
Try the poltice on an unseen area of the granite first to make sure it does not make the situation worse.
If that fails, your going to have to remove it mechanically. (machine it down…ouch!!!!!!!)
November 8, 2011 at 11:30 pm #70028Chris YaughnMemberEtching will change the finish on the top. It will be less shiny.
Could be she got some dyed AB and the cleaner “bleached” out the dye if there is no change in the look of the polish across the area.
Lenny, it is doubtfult AB would have been sealed in most cases as it will not soak up much of anything, sealer included.
Some Tenax Dyes “might” help. maybe….
November 9, 2011 at 8:52 am #70032Un-AuthorizedMemberNovember 10, 2011 at 6:18 am #70039Lenny EMemberJoe,
If you had actually offered some help, I could see asking that question.
February 17, 2012 at 12:22 pm #71235Michelle GoetzingerMemberThanks for your help! It was a simple fix when we went out there is ended up being some type of scale.
we used stone pro’s deep cleaner and deposit remover and some elbow grease and we were good to go! -
