- You must be logged in to reply to this topic.
Viewing 6 posts - 1 through 6 (of 6 total)
First let me say I really like Quartz surfacing products…
BUT, what the hell is this marketing crap about 93% quartz crystals in a slab of Quartz. The percentage is by weight not volume and mean absolutely nothing. Does anyone know the actual percentage by VOLUME?
This seems a bit desceptive doesn’t it? Just my take, I could be wrong.
Andy,
Quartz is about 2.73 times heavier than Polyester, but there are a lot of variables including pigment and particulate size and any thing else added, so the actual volume of poly in a sheet could go as high as 25 to 28 percent. Without any additives the poly content is about 20%
Dani
So just to clarify, quartz is about 20-25% polyester material and 75% quartz crystals. Does this sound right?
I bet Lenny could set this straight.
I heard from several sources that it was around 35%, which if you compare with a concrete mix ( 1 cement, 2 sand and four gravel) it seems reasonable. That works out to 42% cement and fine material combined, or 14% cement alone by volume. Since we are talking about close to the same aggregrate, the fines and cement ratio to “wet” and encapsulate the aggregrate should be simular.
Andy,
Al is right, in some products the numbers could be as high as 30% to 35%. You need plenty of poly to hold everything together. With out that the product would just fall a part.
Dani
Thanks Dani,
But don’t call me right yet, am relying on second hand info myself and logic. You know the old saying about assume, making an a** our of u and me.
I quoted the 35% figure, would like the article to be as accurate as possible.
LENNY!
This site uses cookies. By continuing to browse the site, you are agreeing to our use of cookies.
OKLearn moreWe may request cookies to be set on your device. We use cookies to let us know when you visit our websites, how you interact with us, to enrich your user experience, and to customize your relationship with our website.
Click on the different category headings to find out more. You can also change some of your preferences. Note that blocking some types of cookies may impact your experience on our websites and the services we are able to offer.
These cookies are strictly necessary to provide you with services available through our website and to use some of its features.
Because these cookies are strictly necessary to deliver the website, refuseing them will have impact how our site functions. You always can block or delete cookies by changing your browser settings and force blocking all cookies on this website. But this will always prompt you to accept/refuse cookies when revisiting our site.
We fully respect if you want to refuse cookies but to avoid asking you again and again kindly allow us to store a cookie for that. You are free to opt out any time or opt in for other cookies to get a better experience. If you refuse cookies we will remove all set cookies in our domain.
We provide you with a list of stored cookies on your computer in our domain so you can check what we stored. Due to security reasons we are not able to show or modify cookies from other domains. You can check these in your browser security settings.
These cookies collect information that is used either in aggregate form to help us understand how our website is being used or how effective our marketing campaigns are, or to help us customize our website and application for you in order to enhance your experience.
If you do not want that we track your visit to our site you can disable tracking in your browser here:
We also use different external services like Google Webfonts, Google Maps, and external Video providers. Since these providers may collect personal data like your IP address we allow you to block them here. Please be aware that this might heavily reduce the functionality and appearance of our site. Changes will take effect once you reload the page.
Google Webfont Settings:
Google Map Settings:
Google reCaptcha Settings:
Vimeo and Youtube video embeds:
The following cookies are also needed - You can choose if you want to allow them:
