AuthorPosts
August 13, 2006 at 7:21 am #100
Norm Walters
MemberThere were discussions on the other BB about 15/16 plywood, mdf, ldf and their availability. I haven’t been able to locate any of these materials, and most of my tops are stacked edges. For edge build up I just plane 1″ mdf to 15/16 but when I need to support an overhang I need such a big piece that it won’t fit through the planer without doing it in pieces.
I shy away from doing drop edges for fear that you will see an adhesive line because of an imperfect saw cut, I don’t have a CNC so everything is cut with a saw, and I have had adhesive lines show with a drop edge in the past. Any suggestions would help, these stacked edges are not the most economical way to build a top.
August 13, 2006 at 7:58 am #6547Mory Ludwick
MemberNorm,
We buy 15/16th by the bulk. We can get it in 4 x 8ft, 10ft,or 12ft. We get it from our distributor, which is OHARCO. I am sure they can ship it to you. You can give bill a call. His cell is 630-6189 of the office 342-4489. We like the 12 foot just because we do alot of bar tops and I like to do it in one piece. No reason, just the way we do things.
As far as stacking your edges, all of our tops are done that way. The builders here do not like dropped edges. When they walk up to it they want to feel the thickness all the way back to the cabinet. We come out an inch and a quarter to an inch and a half past the front of the cabinet. This way spills run on the floors instead of down the doors. Anything we do commercial we do a dropped edge. We have a vanity program that is pretty competitive. We are building more and more daily. We also use a dropped edge for this. We recently found a sink for $34.00. They say its all acrylic. We are having one shipped to us and I should have it Monday. I’ll let you know what we think of it. I hope its a decent sink. That will make our vanity program more competitive.
Mory
August 13, 2006 at 11:56 am #6548Andy Graves
KeymasterRun the buildup strip through a table router. That way you will get a perfectly smooth edge.
You can also cut your buildup to lets say 1 1/8″. Then put a featherboard front and rear of the saw blade. Use a nice blade and recut your buildup. This should leave a really smooth consistant cut even though there will be fine saw marks. You shouldn’t hve any glue line problems.
August 13, 2006 at 12:01 pm #6550Andy Graves
KeymasterNorm,
What about 7/8″? Make the stacked edge 1/6″ less in depth than the overhang. Then bump the underlayment to the back of the edge minus a bit. Your customer will still have the thick edge feel, and you can get you underlayment support.
August 13, 2006 at 6:38 pm #6555Norm Walters
MemberAndy, I understand you first post , the second one I am going to give you a call about[EMO]confuse.gif[/EMO]
August 13, 2006 at 6:40 pm #6556John Cristina
MemberWe found a supplier with 7/8 MDF with a white paper finish on one side. Great for hold down boards. If anyone finds a 7/8″ plywood let me know.
Thanks
John
August 14, 2006 at 12:23 am #6557Andy Graves
Norm,
Give me a call.
August 14, 2006 at 4:43 am #6558Norm Walters
MemberJohn, you are in Ft. Myers, I am in Tampa, where are you getting the 7/8″ MDF with the backer on it, it sounds like shelf liner.
August 14, 2006 at 8:09 am #6559John Cristina
MemberA&M Supply is getting it for us. They are going to have it as a stock item for from now on, I dont know how much they are bringing in but I will let my contact know you are interested if you want.
John
August 14, 2006 at 2:37 pm #6563Norm Walters
MemberJohn, I have an A&M supply in St Pete. which is close to me, let me check with them first. Mory, Oharco is getting their MDF from Weyerheuser, I called that company to see if they had a distributor closer to me, still working on it. Ordering from Omaha and having it shipped wouldn’t be cost effective. I’ve spent about two hours calling manufacturer’s to find distributors in my area, what a nightmare. The problem is where I live every countertop I’ve even seen has a single drop edge, my Staron and Hi Macs rep are clueless as to my problem so it’s doubtful that I can get them to order a truck load of 15/16″ MDF which is 365 sheets.
August 15, 2006 at 5:56 am #6572Norm Walters
MemberJohn, the A&M supply you are dealing with must be the one in Pinellas Park, which is the one I use. I called them and they don’t show the 7/8″ MDF with the white backer on it on their system. Can you call me when you get a chance and let me know who your contact is at A&M, my cell is 813-230-2359, thanks
AuthorPosts
- You must be logged in to reply to this topic.
