Viewing 15 posts - 1 through 15 (of 21 total)
  • #478
    Rayne Plane
    I got a complaint today from the BBB. A job we did back in may. Laminate top, customer was told about the thicker and higher counter top and that their cabinets might not be finished on the top rail under the old laminate “build down” top. Hadn’t heard a word except that they wanted us to drop the sheen from high gloss to satin or matte finish when we get to it. Gloss black counter top, yeah we warned her repeatably till she was adamant about the color.
    So other than a extra deep build up, what do you do? Does anyone finish cabinets under these situations?
    All this was discussed prior and we made it plain it was her responsibiltiy for plumbing, caulking and painting.
    I replied to BBB with the details and said we would take it down to matte finish when we slowed down, but were under no oblication to refinish her cabinets. Other than the obvious, any ideas how to handle this?
    #10930
    Al,
    I am not sure I understand. Are you talking about changing a
    high gloss Laminate top to a matte or satin finish?
    #10931
    Seth Emery
    Al,
    Not that I feel you are obligated to do anything, but we install wood trim (not for free) when we have to raise up 3 CM thick tops to meet existing tile, etc. The only thing is though, I don’t know how much area you are talking about that is unfinished and this will lessen the overhang a little.
    Have a nice evening,
    Seth
    #10933
    Al,
    Let me get this straight. You put the countertop on the cabinets so that the bottom of the edge is even with the top of the cabinets. Now you can see the damage on the cabinets where the previous cabinets touched the cabinet and caused damage.
    We always drop the edge down to account for this difference but it is more time consuming to do this. We are looking into working with Affinity 3cm material and were wondering how you all handle this problem.
    #10935
    Sorry Al, but you have to look at it from the customers point of view. Your countertop caused an unsightly experience for her, one which it appears she was left to solve herself. In our area, it would be almost impossible to find someone to put a little piece of trim around the edge, let alone stain it too. She was really relying on you to do a complete replacement. I bet the gloss thing and black just adds to her aggravation. Try using the words “with Black, you will see even the smallest of scratches from across the room” as opposed to “Black will scratch easier”. Then they know why I do not have blacks in my sample boxes. I always tell the customer there might be an unfinished line under the countertop and I charge $100 to fix that if it is there, or they can do it themselves. I put that on the proposal, and note if customer will fix. Everyone has always paid me to do it, it takes just a few minutes to install and pretty good money. Also, coming back to do something else when I have time, means to a customer, sometime in the next month. Not to be critcal of you Al, but I grew up in a family of contractors and have learned from problem stories. It is always , communication!
    #10936
    Al,
    What I do in these cases is put a small peice of trim to cover the area and always let the customer know an exact match wll not occur. Give them the sample colors to chose and then go with what they want. I have only had 1 customer want to do it themselves all the rest were more than happy to pay me to do it.
    #10949
    Al,
    When faced with a “Drop-face” existing counter, and not using solid 3 cm material, why not make the new top drop face? If you are replacing a laminate top and it needs to be “set-on”, maybe the best bet is to run a strip of the same laminate as a trim strip, rather than wood (like to match the cabs).
    I’ve run across a lot of these situations. Call me if you wish (860) 528-5667.
    #10988
    Matt
    Kelsy, we were at the point of “yes, Mam, I’ll shut up and we will use the black.” I tried to turn her off the stuff when I took the deposit check as well, wasn’t happing. I hadn’t thought of using trim, but the customer wants an exact color match apparently, although it was the first time I heard of it, on the bbb complaint. Remember, the last contact was for resurfacing the entire top down to a matte or satin finish, or did I mention that.
    Spot on on the adding to agravation, this is really about the color she picked and insisted on. No one takes six months to complain about the cabinet finishing.
    I’ll put a clause on my estimates about the issue and possible fixes. Thanks for all the help, guys.
    #10989
    Tom, I started out doing 3/4″ build up, leaving 1/4″ drop on the edge. Got away from it due to corner blocks and an occasional build up geting in the way. I might need to look at doing what you and Andy suggest, the drop down in those cases. Not much seam block support with a 3/4″ substrate though.
    #10994
    Okay…I am still confused, did you replace a Laminate top
    with a Laminate top or with a Solid Surface top. And what do you mean;
    “Not much seam block support with a 3/4″ substrate though.”
    I am sure it is me Al, I think I
    need a scotch…or two and then I think it will all make sense….if not…then at
    that point I probably won’t care.
    #10996
    Seth Emery
    Please correct me if I’m wrong, but doesn’t black material usually end up looking like a chalkboard when it is taken to a matte finish? Has the customer seen a sample of this? I don’t know what degree of finish samples are usually taken to, but I would guess that it is semi-gloss. Does she think just because other colors look good with a matte finish that this one will also? Good luck Al.
    Have a nice day,
    Seth
    #11001
    Sen Tran
    Sorry for the confusion. The new top was a K3 avonite top, we replaced the laminate top. Maybe I need a scotch…..
    #11002
    Seth, you are right. It looks like poo when finished matte. We keep 8 x 8 samples of all three finishes of all material we have worked with and she has seen the matte sample of the black polyester. One of the reasons we aren’t rushing in to do the resurfacing, she probally won’t like it when we are done.
    #11003
    Thank you Al,
    We have handled this a few different ways. Most of the time
    it is an issue is with the existing tile jobs because sometimes we can’t tell
    how far the tile lips over the cabinets until we tear them out. In the existing
    laminate jobs we can usually see if there will be an issue right away. In both
    cases, if there is going to be an issue in covering any marks or unfinished
    areas we try to inform the customer of what to expect.
    After we do the removal which is usually done before we make
    the new tops we decide how to deal with it. On the last job we had this issue
    come up we (the customer and I) had decided the best way to handle it was to
    increase the edge thickness to allow more coverage over the cabinet. They paid
    extra and loved the job when we were done.
    Some times people will decide to take care of it themselves,
    and it is funny how when a customer fixes the problem it may look like crap
    when they are done but they think it looks good, however when they have someone
    else do the job it needs to be perfect. Oh well, I guess when you are paying
    someone to do a job your expectations are a lot higher. Other times we have trimmed it with a matching piece of the
    countertop material. And some times they may get someone else to come in a trim
    it out when we are done.
    We also have a stipulation in our contract stating that we
    are not responsible for plumbing, electrical, or painting touch up. But I have
    found that it is still a good idea to go over every detail that may be an issue and
    discuss that issue specifically. If I know that a new backsplash won’t come up
    as high as the old one or if the new top won’t come out far enough to cover an
    old mark I try to point out those areas specifically so they understand.
    I do remember a job
    we did about a year ago and the customer had new wallpaper done prior to
    removing the old tops. When I made a comment about that not being the best way
    to do it she said another countertop shop told her to do it that way, so what
    do you say? I pointed out areas that I felt may be a problem and explained in
    detail that it may not cover. She said she had kept some of the paper and she
    could piece it in if she needed too.
    After the job was
    done we got our survey back and she put on it that she was upset that we did
    not cover where the old top was and she had just paid all this money to have
    the new wallpaper done. WHAT!!! I was so upset I made an appointment with her
    and showed her that these were the same areas that I had specifically talked to
    her about. Ends up that she was upset with the first shop that told her to have
    the wall paper done first and she was taking it out on us. She apologized and
    said she loved the new countertops. I wonder what would have happened if she
    filed a complaint with the BBB before I saw the survey and talked to her about
    it. I could have been made out to be the bad guy.
    Are you a member of the BBB. They keep calling us and saying
    they have a lot of people inquire about our business and that we should join. I
    think it is more of a sales pitch and I see no reason to join at this point.
    lt;br>
    #11006
    Shane, I have been approached by the BBB recently to join. I just don’t think are as relevant now as they used to be. If you get a referral and they check to see if you are a member or not, I don’t believe that you will lose the job if you are not, just my opinion.
