  • #262
    Hi All
    I am trying to find out the best type of lighting for the Avonite glass series. I am doing a vanity with underlit lighting that the customer wants as a nightlight. I was thinking of l.e.d.lights but can anyone tell what manufacturer is best
    David V
    London Ontario Canada
    #8382
    Contact Mory@thefabricatornetwork.com
    He has some lighting websites that are pretty cool. Or You could just wait for him to respond here
    #8384
    I went to a sign makers show a few months back and was introduced to a LED light that was in a tape form. Approx. 1/16″ thick, can be ordered in any width, length, or color. What I liked about it was this exact application, because it can be stuck to the under side of the top directly instead of mounting to the cabinet box and worrying about shadowing. I will try to find the info on it, but it was very cool.
    #8385
    Found it. Check it out, it is a pretty cool product.
    http://www.lighttape.com/
    #8386
    Thanks John
    That is exactly what I was looking for. I have contacted the company and asked for information. When the project is done I will post some pics.
    David
    #8388
    Dani Homrich
    David,
    The problem with L.E.D lighting is the life span. Once a top is installed you don’t want to be fixing dead lights down the road. My Avonite vanity is lit with a Neon tube I had a sign shop make for me from a template. The tube is set in silicone dabs around the edge with the substrate set back from the tube. The advantage of Neon is the 30+ year life span with no heat and very little energy consumption. Make sure your customer is aware of the shadows in the top when lit under neath.
    Dani
    #8412
    Hi Dani
    Thanks for the heads up on the led life span. The neon tube sounds like a good fit for this customer.
    David
    #8413
    Hi Dani
    David
