  • #3905
    Bill Lonergn
    seaming terrazzo counters, fixing chips and polishing how is this done ?
    thanks Bill
    #54209
    What type of Terrazzo are you referring? It gets a bit confusing because there are different types of terrazzo types. For example there is Icestone and Vetrazzo that is sometimes referred to as terrazzo and then there is also material like Enviroglass.
    Both can be fixed and seamed together.
    #54211
    Bill Lonergn
    This is regular concrete matrix with marble and granite chips
    Thanks Bill
    #54212
    Brian Stone
    In general, diamond pads / sanding disks are used to polish these materials. Are you a fabricator that is looking to start selling this product or are you a homeowner that is thinking of making their own tops?
    The tool options will be different if you are doing this once vs long term.
    #54213
    Bill Lonergn
    We are a marble granite fabricator and have never used this material before
    thanks Bill
    #54215
    Brian Stone
    Your normal polishing pads will probably work. Use plenty of water and keep the surface clean. If the sludge dries on the surface it can be a pain to clean off.
    Also, if you don’t use enough water you can grip into the surface and actually pull the aggregate out of the concrete.
    Click here for Vetrazzo’s fabrication guide.
    #54216
    Chips are repaired using an epoxy and then color match to one of the chips in the counter and not the cement binder. As the material takes on a patina you don’t want the repair (that look like the cement) to stay the same color and the rest of the cement to change appearance. When you fill a void or fix a chip and make it look like another chip, it won’t matter what happens to the cement.
    Use crystal clear water. Cement will stain easily and you don’t want you counter to look brown before it’s finished. You can also seal the deck prior to fabrication but on the edges you will still need to use the clean water.
    Read the Vetrazzo manual for best practices and it should point you in the right direction.
    Hope this helps,
    #54242
    Bill Lonergn
    thanks guys you were both very helpful
    Bill
