Viewing 9 posts - 1 through 9 (of 9 total)
  • #159
    What type of Super Glue are you folks using? Viscosity? Size of bottle?
    http://www.palmlabadhesives.com
    #7315
    Sorry. That should be:
    http://www.palmlabsadhesives
    #7339
    I did not get in on the begining of this conversation but we have used super glue as a filler. We did 160 thermo bent e-ticket counters for Air Tran airlines using Gravel and had some issues with voids next to the larger particles. We bought it from a hobby store and i can’t remember a brand name. It had a purple top and came in a fingernail polish size bottle. It was real runny but it worked great. I will try to find a name for you.
    #7342
    David Flock
    Turbo-Fuse come in many viscosities from super liquidy to gel. From 1oz. to 55gallon drums.
    http://www.palmlabsadhesives.com
    #7375
    We use a product called 2P-10 made by Fast-Cap. It also comes in multiple viscosities and uses an aerosol activator for instant curing.
    #7942
    Back when Dinosaurs roamed the earth and I was still good-looking we actually made seams in Corian using super glue and Corian dust. Remeber, in the early years V-grooving was what you routed into the top to fill a joint with phenoseal.
    #7950
    Rich Bell
    Well, maybe I’ll learn something new here. What is everyone using the super glue for? We use it once in a while to fix a dry seam or a void. Any other uses?
    #7951
    Al, we also have granite fabricators that use it to attach adjustable & non-adjustable dishwasher clips. But, only in gel form for that application. You can view all FEDCLIPS AT our website:
    http://www.tools4solidsurface.com
    Look under “FEDCLIPS”.
    #7978
    That is what we use it for, and maybe a quick fix in the field if the fabricators forgot to do a small return for a side cabinet or short wall install.
