January 26, 2007 at 8:29 pm #712
Marcondes Silva
MemberI’ve done many swanstone showers, but a recent kitchen job resulted in the customer asking for a shower pan to put under tile walls. Swanstone didn’t have the right size, 48 x 48, and I am reluctant on using solid surface for the pan in an upstairs master bath.
Being too cautious here? I’d rather lose a sale than my reputation for quality, long lasting work.
January 26, 2007 at 11:56 pm #13806Todd w
Membercheck out http://www.grifform.com/home.asp They aren’t cheap but very well made, exactly to specs, I wouldn’t touch it if I wasn’t doing the wet walls.
Todd
January 27, 2007 at 8:38 am #13814Jon Olson
MemberWe used to make Shower Pans. There wasn’t any easy way to do it. We decided to outsource this part. We use griform. They make a nice pan. (Just got in a nice Mystera pan from them) Bath remodel is a nice market. A shower pan and wet wall project can be a nice cash cow if you plan it out.
January 27, 2007 at 1:45 pm #13844Mark Urbaniak
MemberWe make our Shower Pans, we just glue up two pieces so we can get a nice fall, put the drain in the right location, with alphcam it haves a shower pan add-in, It will programe the Z to fall to the drain no matter where the location is,We use a drain board bit , no need to sand the bottom wtih the drain board bit you get a nice non-slip bottom, Make the curb and there ya have it.
January 27, 2007 at 2:38 pm #13846Tom M
MemberMUrban,
Do you use both alphacam and artcam?
January 27, 2007 at 3:04 pm #13847Patrick McGrath
MemberMUrban,
what is the Alphacam add-in that you are referring to?
January 27, 2007 at 4:44 pm #13850Jon Olson
MemberMurban. Do you fab a dam to prevent water from seeping into the green board? What about pitch what is your angle?
January 27, 2007 at 7:44 pm #13854Mark Urbaniak
MemberYes we build a dam the same height of the curb. Look like a cove back splash, the green board sets on top on the dam (Splash), Then the wall panels goes over the top of the green board and dam down to the pan. you would have to have a 4″ deep pool before it would get to the board.
As far as the pitch i just have to tell alpha cam the fall 1/8,1/4,3/8 etc and click OK , it sets the tool path to fall to the location of the drain.
Hope this makes sense to you
Patrick the add-in is just a VBA Macro, If you have alpha cam just go the add-in and turn on Showerpans
Tom, I don’t have ARTCAM
January 27, 2007 at 10:10 pm #13868Vince McCarthy
MemberWell, maybe I wasn’t clear on my question. What do you guys think about using solid surface as a pan, walking on it, house settling, and so on. I know it makes a great countertop, but will it hold up installed on concrete slabs without cracking after a few years? I would feel comfortable with it on the walls, and the Swanstone pans are reinforced with ribs and the fibers in the product itself. Seems like an acrylic or polyester pan might not hold up well unless it was cushioned in some way from contact with the concrete.
Educate me, please…..
January 27, 2007 at 10:54 pm #13873Tom M
MemberAl,
We never made shower pans, but we’ve sold a few custom-made ones. If you mud it in, or otherwise support it well, there shouldn’t be a problem with cracking from weight. Shock of some kind would be the greater risk.
January 28, 2007 at 12:26 am #13887Andy Graves
KeymasterAl,
Don’t worry about it. It will work fine and we have never had any problems with durability and leaking. I would use Grifform for the pan. The are tested and rated to meet certain plumbing standards
January 28, 2007 at 10:21 am #13908Joe Corlett
MemberAll:
I have toured the shop of Everett (sorry can’t remember his last name, begins with a “B”?) in Indiana who makes a real nice pan and has for years. He has been at most of the shows too. I’ve got an a$$-kickin’ cold today and I’m too lazy to go down and look him up in the Surface Fabrication Magazine.
I’ve bought pans form Meridian Industries, Massillon, Ohio, a.k.a. Todd Werstler, (ISSFA Treasurer?) with excellent results. They’ve got a website too, but I’m too out of it to find it.
I would do business with either of these folks without a second thought.
January 28, 2007 at 10:37 am #13909John Cristina
MemberAl,
To answer your question simply, we love ’em. Most of us here would cover or make any thing in solid surface. If you just use proper technique it will last forever with out any worries as well as looking fantastic. I am not familiar with pans from the two other companies that Joe mentioned but the ones from Griform are realy nice especially the way they do the curbs and other side.
January 28, 2007 at 1:15 pm #13918Krzysztof Strozyk
MemberI can see where grouting it in would make it safe. Might try that.
