Viewing 1 post (of 1 total)
October 25, 2013 at 3:28 am #6147linhvntMember
Compact toilet partition is completely water resistant 100 % , smooth surface is easy to clean . Stainless Steel Accessories for dedicated asynchronous toilet partition . We are one of the single unit design advice and free for customers. Time to provide products , aesthetics and price is one of the advantages of our companyInformation toilet partition compact 100 % waterproofProducts Compact HPL toilet partition used in toilets , public bathroom . HPLtieu toilet partition compact 12mm standard thickness , impermeable , waterproof .Compact toilet partition panels HPL ( High Pressure Laminate ) is produced according to EU standards by multiple layers of kraft paper saturated with phenolic resin , surface covered with 1 layer of melamine . All layers kraft , phenolic and melamine resins are merged together under high temperature and high pressure ( 1000psi – 1500psi , 220oC – 380oC ) to form a unified whole with the dense molecular density . Whereby the water molecules and the molecules of the substance have high antioxidant properties can not penetrate inside to destroy the plates . Sheet size 1220x1830x12mm weight is 40.5 kg / plate , plate size 1525x1830x12mm weight is 50.5 kg / sheet .Compact plate surface is smooth melamine layer for resistance to dirt and cleaning and resists corrosion . Colors surface plentiful to choose from with a variety of colors can match with lots of space and many more ages . However, two gray and cream are the most popular choice because it is both neutral colors should feel soft and clean . In addition, the two colors are not picky color toilet wall tiles .Structure
Compact toilet partition installed along with stainless steel fittings including self-closing hinges , tuning feet up , lock , handles , coat hooks and ke positioning . Accompanied by a system made splint and alley aluminum is aluminum powder coated light gray .Commitment to sell HPL compact panels , 12mm thickness standards , genuine , principal value , warranty 12 T.When purchasing products baffle plate Toilet customers please keep checking the thickness of plate is standard compact to 12mm , because the market is only 11mm plates are genuine aviation customers should ask clearly measure and use clamps .You should not use compact 11mm thick plate , because the whole system dedicated stainless steel accessories for toilet partition and imported aluminum systems are set according to international standards for thickness 12mm and 18mm .If using 11m thickness will make the link between the aluminum plate and fittings loose , not solid walls , the gap will not be good for aesthetics .Hardware:
See more at : http://vachnganvesinh.net -
