March 1, 2007 at 2:47 pm #843
Robert Hoehl
MemberOK, I thought I could get away with a quick plug repair (a series of 4-11/2″ plugs) above a dishwasher and not use a seam support underneath. Guess what? They popped on one side. So now I would like some suggestions on repairing the repair. One other piece of info..the first 2 plugs glued in took too long to dry, but they did dry. The second 2 dried in normal time. I’d appreciate any thoughts on making this the final repair. Thanks, Rob
March 1, 2007 at 8:43 pm #15868Norm Walters
MemberRob, I would get a repair template from Kevin Andreas, he is the repair guru in the industry. After doing the repair I would attach a seam plate under it, only because it is above a dishwasher. As far as the adhesive not setting up, could be alot of things, not purging the cartridge, not purging the tip, adhesive too old, not stored properly, adhesive too cold, there are more.
March 2, 2007 at 12:31 am #15894Karl Crooks
MemberRob, problems with seams or repairs above dish washers is not uncomon. I would sugest that all seams and repair types be reinforced if you can. To go the extra mile add some hard core foam (Home Depot has it) on top of the dish washer to keep the heat and steam away from the top.
March 2, 2007 at 12:43 am #15896Andy Graves
KeymasterHard Core Foam…What is that? Is it in the insulation area?
March 2, 2007 at 7:32 am #15901Mory Ludwick
MemberRob
If you need a repair template i will cut one out of mdf and send it to you. You pay shiping N/C
Morf
March 2, 2007 at 8:27 am #15905Robert Hoehl
MemberThanks all. You have confirmed my suspicion that I should have used a seam plate. I also like the idea of adding the insulation. Mory, thanks for the offer. I may be in touch. Rob
March 2, 2007 at 10:00 am #15914Dani Homrich
Clelotex makes Tuff-R foil faced in 4 X 8 sheets very durable I think the 1” has an R factor of 11
Dani
March 2, 2007 at 12:32 pm #15920Karl Crooks
MemberDani, that all sounds right to me, thanks !
