July 31, 2008 at 5:06 pm #2752Gene McDonaldMember
I did these doors about three years ago whith Chemetal Laminates, I Knew they were going outside i wouldnt warranty them, But I did something very taboo to most…We sprayed them with that primer etch spray to give it a tooth without sanding and then hit it with some strong UV sealer….they are still in good condition…of course the sunlight never hits it…
has anyone ever put laminate exterior in the sunlight??? or outdoor kitchens etc with maybe waterproof plywood or something?
sorry for the bad film, I will take a better picture this week
August 1, 2008 at 11:17 am #41840Andy GravesKeymasterThat entrance looks pretty well protected.
Are all those pieces seperate and glued together. Seems like the water would get in between the pieces.
Looks pretty cool though. Typical Florida design.
August 1, 2008 at 3:11 pm #41847Gene McDonaldMemberThey are seamed up together like a normal ct..but then the top aluminum frame is sealed with Silicone to hide and seal the seams
to me it looked like tony Montana scarface house..it was cool the money they paid for those Laminated doors were crazy
Speaking of doors Andy Check this set out…Avonite with chemetal aluminum. mahogany and more brushed aluminum with a white maple trim.. the bottom metal stuck to soon to the contact on me and heat pulled it up then relayed it and you can kinda see it at the bottom…but the customer was happy…
I miss laminate
August 1, 2008 at 3:28 pm #41849Andy GravesKeymasterI wouldn’t know where to start on a job like that.
How do you quote a job like that?
August 1, 2008 at 4:50 pm #41852Gene McDonaldMember2% of the estimated value of the home or 2% of their annual Household income ( check online for personal info)
or you can just Material times x 4…first you hafta have a meeting of the minds to find out what the interests are and favorites..
for example this guy loves Star Trek and they were the doors to the Home theater…after you proposed the bid and get it…then you go on your material search….Im sure you have peices of SS lieing around…then you just curve the ends and start visualizing shapes….if it helps put on some Pink Floyd and picture floating in outer space these smileys work well with that visual
hehehehe…anyway try to make a set for your showroom doors…then submit the picture to all the Home theater companies just like we submit our CTs to cabinetmakers
August 7, 2008 at 10:40 pm #42132WagsMemberGene your a true artist, beautiful work. Problem we have here in Az with laminate and contact adhesive, it gets too hot. I had a customer that recovered a trailer full of slot machines with laminate. The ones with the rounded top. Loaded them in a trailer, delivered them a few days later and all the laminate had delaminated from the heat. In fact, one distributor had a shipment of rolled melamine (paper with hot melt on the back basically) it was black, when they took delivery the whole roll had fused togather from the heat in the trailer. The hot melt had a reactive point of bout 180 degrees. Gets a tad warm here….but it is a dry heat……much like a commercial convection oven 🙂
August 8, 2008 at 4:15 am #42138Gene McDonaldMemberThanks Wags…I did hear stories rom the other magazines i read Like about Arizona will delaminate your countertop if its designed near windows…..just got take that into cosideration, installers probaly cant use an open truck to deliver SS either I would suppose….Thermoforming on the way to the jobsite….
August 8, 2008 at 8:08 am #42141Reuben Hoff IIIMemberI had a small top had people in hurry for and needed to place oudoors. As in next day deal. Well i did not have enough of any SS to make it for them so I told them can de it with laminate peice MDF and no gaurantees to how long it would last. It came back about two weeks later after we hit a couple 100 degree days. You could tell where the umbrella covered from direct sunlight by the delamination started and ended.
August 8, 2008 at 8:09 am #42142Reuben Hoff IIIMemberWgas,
Whatta they do for adhearing the laminate down with in those cases then?
August 8, 2008 at 8:25 am #42145Tom MMemberReuben,
The new PVa(C?) type glues will work, but you need to set up a press for it.
Carpenters glue (ditto the press)
We use National Casein #705 glue (and hot press it – bakes the urea-formaldehyde out).Understand, contact cement is only used because of it’s convenience for on site and gravity-defying characteristics. Lots of glue will adhere laminate to a wood substrate.
August 8, 2008 at 9:26 am #42149Reuben Hoff IIIMemberFeed me, Seymore Feed Me. I wants to learn more about this press stuff or I will uh well i do not know what I will do.
August 8, 2008 at 10:59 am #42154David GerardMemberWhy is it the after removing old laminate from ply the glue seams tacky or greasy? Is there something in the ply that does this. When I incounter a delam I can guess that it was on ply.
July 2, 2013 at 7:23 am #75666KevinRossMemberYou can use fiberglass or even steel doors if you does not like wooden doors. Mostly used as Fiberglass Entry Doors Toronto, these doors prove to be the best choice for installation as well as replacement purpose to keep safe from sunlight and also bad or harsh weather conditions.
