April 16, 2007 at 5:46 pm #1018
Fred Atwood
MemberI was working on finishing a set of darker tops and although the finish looks great, there was quite a bit of very fine dust that would not wipe off with a dry rag. How are you guys cleaning your tops before delivery ?
Thanks!
Fred
April 16, 2007 at 5:52 pm #18529Andy Graves
KeymasterWe usually clean our tops after we install with window cleaner. The static electricity in the material after sanding makes it hard to clean with a dry rag, especially in the shop with the dust.
April 16, 2007 at 5:53 pm #18530Fred Atwood
MemberAndy…just simple Windex or the like?
April 16, 2007 at 6:02 pm #18531Paul Bingham
MemberWe put a coat of Counter top Magic on all of our tops after wiping down with a damp rag.
Paul
April 16, 2007 at 6:13 pm #18533robert seke
MemberFred,
There is a product that Joest manufactures, which is called a dust-disc. This non-abrasive pad would simply be put on your sanding pad, following your sanding process. All static dust would be picked up with this disc and stored in the fabric. It truly is a simple, yet effective remedy to remove all static and dust. This dust disc can be ordered through Federal Saw and Tool.
Robert
April 16, 2007 at 6:54 pm #18536Todd Roston
MemberSquegee, bucket of clean water and a chamois is what we do. Cheap….
April 16, 2007 at 7:19 pm #18539Andy Graves
We clean the tops with water in the shop and then at the job we do a final cleaning with Windex or actually the Class Cleaner from Costco. That’s it. No complaints in 20 years.
April 16, 2007 at 7:23 pm #18541Fred Atwood
MemberAndy….I assume you do this on site cleaning before caulk at walls or set on splashes?
April 17, 2007 at 7:53 am #18557Matt Kraft
MemberWe wipe em down with a microfiber towel (3M makes one type) that picks up most of the dust, and cuts through static, then clean up with Windex usually.
April 17, 2007 at 9:03 am #18558Nick Heidenreich
MemberMatt, that 3M Micro fiber towel is awesome! They’re about 6 bucks a pop but they pick up everything. Great for cleaning your glasses as well. Never heard of using them for cleaning solid surface. Great suggestion. Thanks.
April 17, 2007 at 9:45 am #18561Matt Kraft
They are great. You can wash them, just can’t use fabric softener. $6 bucks a pop, but they last forever. They pick up SS dust extremely well.
April 21, 2007 at 5:54 pm #18746Wade Stein
MemberSam’s and Costco have those microfiber towels also, they come in a package of about 10 or 12 and if I recall they were about $15.00. Hopefully I did not step on your toes Dave.
Wade
April 21, 2007 at 6:10 pm #18748Frank Zamora
MemberNo Wade, you didn’t. There are differant thickness’ in the 3M micron towels. I have not purchased them in quite a while. I bought a 100 ct. box and gave them out at one time. Not sure what Costco is offering. Will check out.
One thing is for sure, like was stated, you can not use fabric softener when you wash them.
April 21, 2007 at 9:09 pm #18768Tom M
Careful, Paul. That’s a coating. It will leave a film.
April 21, 2007 at 10:22 pm #18776Joe Corlett
Tom:
Yeah, it leaves a film. A film that causes water to dance like Fred and Ginger. A film that makes a Scotch-Brighted top look like a polished one. A film that leaves no fingerprints or static.
