April 23, 2007 at 2:39 pm #1037
KeymasterWhat size bit do you use for drainboards? I have seen them with a skinny core box bit and also a wide bit up to 1″. Just curious what you all used.
April 23, 2007 at 3:09 pm #18858John Christensen
I use a 5/8″ dia. with rounded corners. I like to cut 1/16 deep on the shallow end and 3/16″ deep nwhere it enters the bowl. I do not add reinforcing under the drain board and have not had any problems.
April 23, 2007 at 3:17 pm #18861Paul Bingham
MemberSame as Johnny C.
Paul
April 24, 2007 at 12:37 pm #18911Shane Barker
We use this type of bit and mostly use the 1/2″ dia. The bits shown are 1/2, 5/8, 3/4, & 1″. We will cut ours from 0″ to 1/4″ in depth.
April 24, 2007 at 1:07 pm #18912Matt Kraft
MemberWe use a 3/4″ as a standard, but have done 1/2″ and 1″
Want a really cool effect?? Do a 1/4″ stripe inlay in the drainboard. Looks sharp. Let me see if I have a picture….
April 24, 2007 at 4:29 pm #18916Gary Thompson
MemberMatt, I’ve seen something like that done and you’re right, it is very cool! Hope you have some pics to post.
April 24, 2007 at 5:03 pm #18917Andy Graves
Don’t leave me hangin, I need to see a picture of this. I get a lot of comments about drainboards about things might tip over if the groove is too wide. The 1/4″ bit my be the answer.
April 24, 2007 at 7:37 pm #18928keith kalman
MemberDoes it need to be that wide, 1/4″? Would the water bead up and block the flow or something?
April 30, 2007 at 10:38 am #19187Andy Graves
KeymasterMatt,
Were you able to find a picture of that Drainboard with the 1/4″ bit? Just curious
April 30, 2007 at 11:31 am #19188Gordon Shell
Not trying to spam, here is a deep drainboard done in 3cm, pretty wide bit.
April 30, 2007 at 12:24 pm #19190Andy Graves
KeymasterGordon,
Do you happen to know what size bit that is?
May 1, 2007 at 7:05 am #19220Matt Kraft
Couldn’t find one, but I will take one today and get it posted.
Matt
May 1, 2007 at 7:40 am #19222Gordon Shell
MemberI believe the bit that was used on the EOS pic is a 3/4 cut with an 1/8″ radius in the corners. Dave has one in the Velepec catalog.
