December 8, 2010 at 9:37 am #4790Richard MageeMember
Questions.
I don’t know where to put this so I’ve added to this forum.
What are the most common sinks used in concrete tops? Are there concrete sinks that are seperate from the tops, much like solid surface sinks. I know there are molds for concrete sinks avalable but how does the sink get married to the top. I always thought the most common sink in concrete was stainless steel or that the sink was poured as part of the overall top construction?
What about cost. Concrete vs. solid surface, vs stainless.
Inquiring minds want to know.
GEMSTONE
December 8, 2010 at 6:53 pm #64740KCWOODMemberGeez Rich, you already have the best products out on the market… are you wanting to set your sites on something else??
December 9, 2010 at 6:50 am #64752Richard MageeMemberThank you Kelsey for the kind words.
Actualkly more curious than setting my sights on something else. Trying to figure out the market.
We believe we make the best sinks and bowls available and just want to know where else they could and can be used.
Always trying to stay one step ahead.
Respectfully,
GEMSTONEDecember 9, 2010 at 7:46 am #64753Brian StoneMemberI don’t really deal with concrete too much but every time I picture it in my mind it has a hammered copper sink or a sink that is cast with the top. In my opinion a solid surface sink wouldn’t look ‘rustic’ enough.
If I was mounting a solid surface sink to a concrete top I would grind the bottom of the concrete flat and either use blocks in the cabinet or the glue on sink mounting hardware, and then silicone the sink in.
December 9, 2010 at 12:14 pm #64763Richard MageeMemberBrian,
Thank you for your input and ideas.
I’m trying to find out what sinks are most commonly used in concrete tops, and why.
Almost everything I’ve seen appears to be stainless or other materials, vessel sinks in glass, copper, or formed from concrete. Just trying to ascertain how many concrete tops actually have a concrete sink either formed or added.
How expensive are concret sinks vs other available sinks?
GEMSTONE
December 10, 2010 at 10:52 am #64791Andy GravesKeymasterWe see Stainless and those Quartz sinks in the concrete tops along with the molded concrete sink.
Solid Surface wouldn’t lend itself well with concrete, just a different look in my opinion.
December 10, 2010 at 12:03 pm #64802Richard MageeMemberAndy,
Thank you for your input. I agree solid surface just wouldn’t do it, functionally or looks wise.
Which do you think is most prevelent stainless or molded concrete?
How’s the cost of a concrete sink vs a quartz, solid surface, stainless. $XX + 20%, $XXX+ 30%?
GEMSTONE
December 11, 2010 at 10:06 am #64834TopshopMemberIs ther anyone who pre-casts concrete sinks? I thought they were cast with the tops – but then again I have seen only a couple concrete tops in my area anyway.
December 15, 2010 at 4:22 am #64966Andy GravesKeymasterRichard,
We don’t do enough concrete for me to know. The concrete that I see is typically stainless steel because of the vast selection and the relatively low price.
Solid surface is the ultimate sink/counter combo, but you have to be willing to accept the matte sink finish as opposed to the shinny with the stainless and cast iron.
December 15, 2010 at 9:19 am #64970Richard MageeMemberWhat , if any, would be the advantage of a pre-cast concrete sink? How would you attach it to the top?
It’s not like solid surface where you glue it up?
Are there pre-cast concrete sinks available?
Curious minds want to know.
GEMSTONE
December 15, 2010 at 11:14 am #64971Andy GravesKeymasterIf the concrete had a flange, you could mount it like you do a cast iron. Either use the sink setters or you could use a wood frame.
December 15, 2010 at 2:40 pm #64980Brian StoneMemberThe only advantage to a pre-cast concrete sink that I can think of is that you could sell the sink separate to install in other products as well.
January 4, 2011 at 11:00 am #65385Richard MageeMemberPosted By Richard Magee on 15 Dec 2010 09:19 AM
What , if any, would be the advantage of a pre-cast concrete sink? How would you attach it to the top?It’s not like solid surface where you glue it up?
GEMSTONE
Same questions – different day?
GEMSTONE
January 5, 2011 at 3:33 am #65400Sam GrahamMemberGenerally the concrete fabricators use stainless sinks their tops. Kind of goes with modern look.
As for cast concrete sinks usually they are integrated into the top as a whole. Don’t really know of any concrete sinks that are sold separately.
My good friend owns http://www.goredesignco.com I used to do a lot of installs for Brandon back in the day before he moved into just strictly design and fab of custom sinks and training, and I moved into luxury home building. I still remember the first concrete kitchen he and I installed together. It was in a prominent architects home and neither one of us really knew what the heck we were doing. Stay cool and fake it till you make it:) Turned out great!
All of the sinks were installed just as you would on a quartz or granite top.
The real trend in concrete is an integral sink in the vanities and stainless in the kitchens. However a black gemstone sink or a grey one, like the ones Blanco makes, could be a good fit in bathroom vanities. Those could be prone to show a ton of wear though:(
Of course a bright white SS sink on a white GFRC top could be a good combination in a commercial vanity application.
January 5, 2011 at 10:25 am #65403Richard MageeMemberSam,
Thank you for your input and reply.
This is turning out to be an interesting research project. It would appear that almost all concrete jobs have the sink cast in at the same time the top is made or use a stainless steel or hammered copper sink, and that the only real possibilities for a molded precast concrete sink would be for the E-stone (Quartz) and / or granite top fabricators.
I’d really like to hear from some of you fabnetters who are doing the two aforementioned surfaces as to what you preffer for your Quartz or Granite tops and whether or not the availability of a concrete sink would be benificial.
Still looking for answers.
Respectfully,
GEMSTONE
