March 26, 2007 at 4:09 pm #929
Dirk Williams
MemberWhat is the most overhang you can have on a Kitchen bar with no supports on a 2×4 wall with 1/2″ drywall and 1″ overhang on inside? With 3cm material bar is L shaped 90″ X 57″.
Dirk
March 26, 2007 at 5:16 pm #17135Tom M
MemberDirk,
Welcome to the FabNet.
Official rule is: 1/2″ material = no more than a six inch unsupported overhang. This could easily be extended with steel or ply recessed in as substrate or build up. If we were talking about a peninsula or island on cabinets, you could push it to twelve – more with the steel we use.
The cantilever rule is in play, however: two-thirds support for one-third free overhang, but you can squeeze a bit more if you first fasten your solid medite (MDF board) or ply build up direct to the wall, then fasten the top to that.
Your question is somewhat lacking in detail, but this should keep you safe, anyway.
Is there a particular situation you’re worried about?
March 26, 2007 at 7:15 pm #17144Joe Corlett
MemberDirk:
DuPont’s Zodiaq 3cm quartz surfacing remains under warranty with a fourteen inch unsupported cantilever.
I’m not saying that’s what I’d recommend for a 2×4 wall, however.
March 26, 2007 at 10:12 pm #17161Andy Graves
KeymasterHow do you plan on attaching it to the wall? If there is nothing supporting the 3cm material, when you lean on it, what is going to happen?
March 27, 2007 at 10:00 am #17172Dirk Williams
MemberWhat I have is a 13″ bar top sitting on a standard 2×4 Halfwall attached with silicone on the kitcken side I have a 1″ overhang on the other side somewhere around a 6″ overhang with 3cm EOS. What I was wondering was at what point do you need supports under the overhang 6,7,8,9….”. Like with Andy”s question when someone leans on it.
Thanks for all the advice
Dirk
March 27, 2007 at 10:55 am #17178Tom M
MemberDirk,
Under the circumstances you describe, I would definitely go with some kind of bracket support.
As for any other general overhangs, as long as it falls within the max allowed limits, I would follow the two-thirds rule.
March 27, 2007 at 7:45 pm #17221Gordon Shell
MemberEOS allows 12″ unsupported overhangs, I’m a little sketchy on the details you gave but it sounds like you are going to need some support just to keep it from teetering on the wall.
March 27, 2007 at 8:20 pm #17224KCWOOD
Dirk
Dirk….. Order you several corbels to support an application like that. About any bar overhang, not only will you convince the homeowner it needs it, but you will pick up and extra $100 for every 4 you install. Send me an email, I’ll send you my source. they are are just an ups delivery away…
KC
March 27, 2007 at 10:16 pm #17236Tom M
MemberGot it.
There are brackets that have no angle support. Sure, they give up some strength, but they are pretty strong anyway. You really don’t need much, do you? Just a bit more than is wise without support.
If you have access to the stud, fasten them between the stud and the sheetrock. If not, face mount it and carve some caps out of the material for cover later. Recess route the top rail into the material. I doubt you’d influence it at all in the negative, but Gordon is the official EOS go-to guy.
This is going to cost a little, but it essentially satisfies the criterion of the homeowner, while leaving little more than a decorative doo dad. It should cost something, and you should profit from it.
March 27, 2007 at 11:14 pm #17239Chris Yaughn
MemberMy thoughts on this are, go with KC and make it look nice while adding alittle to your pocket (with minimal extra work). Or go with Tom, figure out a way to get the brackets under the sheetrock ( with alot of work) and make it look like it floats (charge alot more).
At the very least, if I understand the description right, the limit of the countertop is not the question as much as the limit of the connection to the wall. Whatever you do, if there is even a small tiny doubt in your head, don’t leave it hangin with no support. You will never be able to get any sleep.
March 27, 2007 at 11:31 pm #17245Tom M
Member‘Cause I don’t know about you, but the idea of 15 per square greeting my bare feet in the morning is, well, undesired.
If it’s gonna look like it’s special, and work well at the same time, it shouldn’t be cheap.
You can’t just give away your liability, what would tort lawyers live on?
March 27, 2007 at 11:52 pm #17249Andy Graves
KeymasterI wouldn’t go more than 3″ without some sort of bracket or corbel. As soon as someone lean on it the thing will start coming loose from such a small surface area to silicone.
