March 1, 2011 at 12:56 pm #4933Travis HarperMember
Ok a few years ago I created some lisps as shortcuts. One lisp was called bolt.
Well I opened the dwg. and changed the look of my bolt and hit save.Now when I type bolt in a drawing I get an error. What did I do?
-Insert Enter block name or [?]: C:/Documents and Settings/Administrator/My Documents/LAYOUT/MISCELLANEOUS/bolt.dwg Block bolt references itself *Invalid* ; error: Function cancelled
March 1, 2011 at 1:05 pm #66491Andy GravesKeymasterThis is a question for Seth.
March 1, 2011 at 6:30 pm #66501Seth EmeryMemberThanks for the vote of confidence, Andy. Travis, here is the lisp function I use for inserting a “CABINET” note (as a block .dwg file):(defun c:cab ()
;define the function;**********************************************************
;Start of Command Function
(command “-Insert” “R:/Layout/Miscellaneous/cab.dwg” pause “” “” “”
“_Explode” “Last”
) ;End Command
;End of Command Function;**********************************************************
(princ)
;finish cleanly);end of defunTry navigating to your .dwg file in Windows Explorer and making sure the path is still right. Compare it to what is in your lisp file. Is there a chance that you changed the file type? You may want to copy your bolt object into another drawing, close the original bolt drawing, and then export the bolt object as a block and overwrite the original .dwg (block). It’s worth a shot.I hope this helps. Please let me know if it doesn’t, and I’ll look into it further.Have a good one,SethMarch 2, 2011 at 1:04 pm #66510Travis HarperMemberWell it is still not working. Here are 2 examples. Seem works and bolt does not.
(defun c:seem ()
(command “-Insert” “C:/Documents and Settings/Administrator/My Documents/LAYOUT/MISCELLANEOUS/seem.dwg” pause “” “” “”
“_Explode” “Last”
) ;End Command
(princ)
;finish cleanly
) ;end of defun(defun c:bolt ()
(command “-Insert” “C:/Documents and Settings/Administrator/My Documents/LAYOUT/MISCELLANEOUS/bolt.dwg” pause “” “” “”
“_Explode” “Last”
) ;End Command
(princ)
;finish cleanly
) ;end of defunMarch 2, 2011 at 1:06 pm #66511Travis HarperMemberAnd this is the error in ACAD that I get
*Invalid*
; error: Function cancelledAll I did was make changes the size of the part and hit save then closed the drawing.
March 2, 2011 at 1:18 pm #66512Travis HarperMemberit is saved as acad2000.dwg
Do I have to use the block function in ACAD? The error says it is referending itself ??? Dunno what that means
March 2, 2011 at 8:10 pm #66517Seth EmeryMemberTravis,
I never had this happen, but here is a link that explains what is going on: http://forums.autodesk.com/t5/AutoC…-p/2763094. Here is another one: http://www.cadtutor.net/forum/showt…ces-itself.I’d open the bolt drawing. Purge “all” several times to make sure everything is purged. Save and close that drawing. Open your setup drawing (assuming you have one). Enter Purge -> Blocks -> Bolt (if it is embedded in your setup drawing) -> Purge Button. This way the bolt block is redefined automatically when you enter “bolt” on the command line.If your still having problems, give me a call (7179173259) – sometimes things are easier to figure out over the phone.Have a good one,SethMarch 5, 2011 at 9:50 am #66553Travis HarperMemberWell Seth I gotta say you are a damn genius.
It worked … whoo hooo
Life is great again
Thanks for your help
March 7, 2011 at 5:16 pm #66563Seth EmeryMemberI’m glad it worked, Travis. Thanks for the compliment that was the overstatement of the year
March 7, 2011 at 11:07 pm #66566Chris YaughnMemberI have no idea what you guys are talking about, but I am pretty sure I like EasyStone even more now.
